![]() | Home > Maintenance & Modifications > Dampers: OME vs. Terrafirma?? |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3497 ![]() ![]() ![]() |
Tried both. Current TD5 on new OME and my best mates on TF. Just been out for a spin in a mates 2013 110 and surprised again how bouncy the ride was on OE shocks.
Other mate with the TF set up rides like its got no damping. Very sporty but crashes over even the smallest ruts and bumps. The finish on his shocks also came off within 12 months and look pants. Would do my nut in the way it rides. OME plush, smooth and nuggety ride. Feels almost jag like compared to a stiffly sprung German machine. You pays your money ......!! 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 824 ![]() ![]() ![]() |
^^^ Agree Tf are fine on a budget but can be a tad hard pending your set-up.
Have you considered Koni shox...In my opinion much better than OME and adjustable too ![]() N. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5983 ![]() ![]() |
Tf are poo. Cheap, nasty, badly finished, poorly designed.
Didn't even think what was the retaining washer size whilst designing ![]() Click image to enlarge Andy |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
TF - avoid OME - good Bilstein - better Koni - even better ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Yes I put Koni Heavy tracks under my Camel Discovery and they are great. Mine could be adjusted in 3 settings Normally I was driving is the middle setting, but on holidays I put the rear in the 3rd setting for a little more stability with a full roof rack. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
tazmarkuk Member Since: 24 Jan 2012 Location: Birmingham Posts: 134 ![]() ![]() ![]() |
Had TF Bigbore for last two years and died, one of the front had also started to leak, change to Old Man Emu Nitro Sport +2 with springs, they are firmer than the TF but with the harshness, towing 2 tonne caravan been fine so far
