![]() | Home > Technical > Traction control Td5 |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
Blimey, that seems a brave way to check the TC..
![]() I'd go and find a bit of loose gravel and try it there. You can also try the ABS on a quiet bit of road. I did both of these with my TD5 after I changed the modulator and it worked fine. I'm not sure how much speed you need to have TC kick in, so may not work in your scenario above. Cheers Simon |
You're probably better off trying it out in a cross axle situation, try climbing a large rock without difflock, the traction control should try to brake the wheel/s that are next to leave the ground and you can feel this occouring from the drivers seat.
v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 452 ![]() ![]() ![]() |
Not brave really. The wheel was just off the ground and not much in the way of throttle.
I think curiosity got the better of me. I will try and find a crossaxle situation to see if the TC assists in reality but having one wheel artificially off the floor is essentially the same thing. From having a bit more of a search on t'internet this evening it seems that the TC works better with a bit of revs which makes sense and I wasn't keen to give it a bootfull of revs on the drive. I will do some more playing. Dave |
Your wheel has to be spinning minimal 7 km/hr as I recall right so you need some throttle input before it starts working. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
