![]() | Home > Technical > Fire and Ice side step |
deplec Member Since: 21 Aug 2012 Location: Yorkshire Posts: 152 ![]() ![]() ![]() |
When I fitted these steps to mine I seem to remember not needing to use the supplied new rivnut as the one for the normal step was already there. That said it took me hours to fit them as I am mechanically incompetent so others who know better will be along in a minute.
A suitable 'rivnut' with the correct thread will suffice. If you go for OEM you'll still need the tool depicted in the left corner of the pictures to fit it.
There is also the below option of the home made rivnut tool...... http://www.defender2.net/forum/topic8631.html?highlight=rivnut If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Zouritte Member Since: 29 Jan 2014 Location: Ain Posts: 69 ![]() ![]() ![]() |
thanks for your help, i've found the details, it's a M6 Rivet-nuts hexagon.
Thanks |
Very welcome.
![]() Treat every day as if it is your last....one day you will be right!! |
Your local engineering / fastener supplies place will be able to provide you with a handful for very little money. Steve.
driver Member Since: 02 Aug 2009 Location: bude , cornwall Posts: 206 ![]() ![]() ![]() |
Try ebay thats where I got mine from.
