![]() | Home > Puma (Tdci) > Speedometer thinks its a rev counter!--Sorted |
Buz Member Since: 24 Jan 2014 Location: Forest of Dean Posts: 238 ![]() ![]() ![]() |
My 90 does that.
Ive replaced the speedo unit in the dash and the speedo cable so it must be the actual drive that the speedo cable goes in to that is knackered. It would seem 'they all do that sir' it must be an added feature, like the free shower with every rainstorm ![]() |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
Theres the speed sensor on the transfer box if I am not mistaken??
I would start there Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
davidhenry Member Since: 28 Jan 2014 Location: Ceredigion Posts: 6 ![]() ![]() ![]() |
Thanks for the tips....will get outside and poke about underneath......if it ever stops raining that is!...cheers
Thanks for the tip!..............finally took a window of opportunity when the clouds parted and had a good nosey at the sensors on the transmission after removing the cubby box and floor. Wiring to sensor which is located on transfer box behind the handbrake drum base was chafed where it had been rubbing on the drum itself......fixed wiring and all well with the speedo again so well happy... Cheers ![]() |
Glad your sorted
![]() I removed the handbrake unit from my mates puma tonight to free up the ajuster & fit a new cable Could clearly see the sensor there ![]() 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
