Home > Maintenance & Modifications > Synchro works slick shift
Page 2 of 3 <123>
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Few pics ...
First is in the central position. 2nd, 3rd and 4th are all in 4th Gear. Last one shows the height!
Post #351345 13th Aug 2014 8:41am
roel
What does it do?
Is it just because you put the pivot point higher that your gearstick movement is shorter? Roel
2003 90 Td5 (2009-now)
Post #351350 13th Aug 2014 9:02am
taazzukcb
Yeah, it just creates a short shift essentially. More distance between the 2 pivot points with some CNC spacer blocks in between.
Fairly simple, but IMO, fairly effective!
Post #351359 13th Aug 2014 9:34am
roel
Till now I didn't think I needed that. Very Happy If will have a look at my next drive. Mr. Green Roel
Post #351369 13th Aug 2014 10:03am
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
taazzukcb, did you have any problems contacting them, as I've tried on a numerous occasions and cant get through, I know there web site states they are out of stock of the slickshift.
Post #351373 13th Aug 2014 10:33am
taazzukcb
Not really had need to contact him directly. Just bought online and it turned up about a week later! Sorry that's not of much help!
Post #351524 14th Aug 2014 8:31am
taazzukcb
This is my rattle ...
Notice near the end I start playing with the stick to find the quiet spots ...
Going to have a play with the bias springs over the weekend. I'm almost certain that should do it!
May also do the plastic bush to as I just realised how it pops out ... Not how I expected or tried!
Post #351572 14th Aug 2014 2:42pm
Fullfat
1999 Defender 90 Td5 HT Rioja Red
Anyone manage to get a response from the seller?
Thanks
Post #353451 24th Aug 2014 9:59pm
jhnstap
United Kingdom 2005 Defender 90 Td5 XS CSW Tonga Green
Slick shift from Synchro Gear boxes
E mailed Shabs 3 weeks ago, got a response straightaway-that they would be available in September-see they are available on his web site today, so just placed order
Price has risen to £75 but now includes nylon cup, and now allows you to keep your original gear stick I do my thing and you do yours. I am not in this world to live up to your expectations, and you are not in this world to live up to mine
Post #358850 19th Sep 2014 7:55am
ibexman
Seem like it's back albeit with £25 increase how does he justify that then Whistle
Post #359257 21st Sep 2014 5:50pm
taazzukcb
Materials have been improved by quite a bit and the machining of the shifter is far more than before (and to better tolerances) to allow the wear spring to be utilised as well as the original lever utilised. The nylon cup is also included in the price.
Post #359262 21st Sep 2014 6:46pm
df1
Got and fitted slickshift today, happy with quality and improvement in shifting.
No vibration as mentioned earlier.
Takes a little bit of fiddling to get the bias springs how you want them, other than that straight forward fit.
Post #361484 1st Oct 2014 6:56pm
Fullfat
Fitted mine last week and must say it makes quite a difference to the gear change, its a very short precise gear change compared to the stick in the bucket gear change it was before.
Fitting only took 10 mins and I also had a play with the spring which took out the slack.
Also repainted the gear shift as it was badly worn,
Well worth the money in my opinion.
Post #361516 1st Oct 2014 8:13pm
Ken B
Just fitted one of these today.. What a great improvement!!! i can really feel the tightness shifting up through the gears.
I do need to play with the adjustment as the downshift from 4th to 3rd has always been bad for me (assume it is just my gearbox) and now with a much shorter throw it feels a little more pronounced but that is because i was so used to where in amongst the bucket of options previously to push the stick.. Laughing Defender 90 TD5 County -
You need only two tools in life: WD-40 and duct tape.
If it doesnt move and it should: WD-40.
If it moves and shouldnt: duct tape it.
Post #400071 18th Feb 2015 7:07pm
df1
Paddocks stocking this now, more user friendly ordering process I'd imagine.
Post #400373 19th Feb 2015 8:00pm
Page 2 of 3 <123>
