Home > Maintenance & Modifications > Please diagnose! Is my clutch dying?
ZeDefender
I need some help from other "clutch victims" or those in the know...
Recently, when after partial load, I've begun to hear what sounds like heavy diesel nailing, worst around 1700rpm. It doesn't happen when in neutral at any engine speed and disappears when the engine is under heavier load. It seems to be at the same frequency as the normal nailing but it's louder and more "mechanical"
I thought it might be the injectors but the indie isn't so sure. When idling in neutral, he noticed some very light clanking with the clutch engaged vs. not.
I've tried the "stopping in neutral with the clutch in/out" trick but it just clanks in both cases. My clutches in other cars have just worn out in the past so I'm none the wiser.
Is it possible that the clutch springs are on the way out with these symptoms?
Help please?
Matt Tell someone you love them today because life is short.
Post #351228 12th Aug 2014 2:54pm
Caterham
Is it always a problem at 1700 or is it intermittent?
Have you noticed another symptoms?
Post #351263 12th Aug 2014 6:40pm
ZeDefender
It's always worst around there, especially if I "rest" my foot on the pedal (not quite coasting) so there's just a little load. Tell someone you love them today because life is short.
Post #351272 12th Aug 2014 7:16pm
Caterham
When you say pedal I presume you are talking clutch pedal?
If you mean throttle and talking about the same problem as me -then bloody good luck to you!!!!!
Post #351285 12th Aug 2014 9:04pm
ZeDefender
I mean throttle... Shocked Tell someone you love them today because life is short.
Post #351301 12th Aug 2014 9:54pm
Caterham
Thud
......oh dear.
Any of this sound familiar;
Very light throttle, just enough to go from coasting to fueling the engine at say 60mph sounds like injector knocking,
Turning engine off gives a very abrupt stop (but not always - depressing clutch when turning seems to improve things),
Gentle acceleration can be a kangaroo(ish),
Circa 1700 rpm can be like a step from running well to not well (or vice versa - can't recall which way round)
Transmission seems rubbish and getting smooth gear changes very difficult - again intermittent
These are my symptoms and I believe it's all down to an intermittent electrical problem.
Post #351307 12th Aug 2014 10:10pm
ZeDefender
Some of it sounds familiar, although acceleration and gear changes are okay.
I'm 50% for injector/fuel problems and 50% for clutch springs at the moment. I guess it's one or the other. Indie seemed convinced I hadn't melted the pistons or anything more serious (new turbo gets things a bit hot...). Whatever it is, I guess it'll get sorted eventually - just need to find a third job now Rolling Eyes
Perhaps if I figure mine out it might help you Smile
Post #351312 12th Aug 2014 10:21pm
Caterham
Good luck mate.
In terms of gear changes I went from thinking it was engine related to clutch and now back to engine.
Post #351317 12th Aug 2014 10:39pm
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
Hi are they Puma's or TD5's
Post #351332 13th Aug 2014 7:15am
K9F
By their avatar details I would 'hazard a guess' and state perhaps the obvious......Pumas. Thud If you go through life with your head in the sand....all people will see is an ar5e!!
Post #351333 13th Aug 2014 7:19am
tazmarkuk
yeah that would state the obvious, however there full details don't load up on my ipad
Post #351377 13th Aug 2014 11:22am
