![]() | Home > Td5 > Blower fuse keeps going. |
benn Member Since: 12 Aug 2014 Location: southampton Posts: 3 ![]() ![]() ![]() |
just so you know the aux power
(fag lighter) is connected to the blower wiring so if you prob solving then maybe look in that direction? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6048 ![]() ![]() |
Have you checked the drain on the heater intake system, to make sure it not keeping water in?
Andy |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 271 ![]() ![]() ![]() |
Thanks for the heads up on the auxiliary socket.
Andy, I will definitely check on the drain, with someone else pointing me in that direction also. I wouldn't have thought to look there. Will take a look in the morning. Thanks. |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 242 ![]() ![]() |
+1 for the drain,
Think it was Andy that solved this problem for me as well with the same solution Will Defender 90 XS TD5 (03 Reg) |
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 ![]() ![]() ![]() |
Drain for sure. Check down there and see if the motor can spin freely. Most likely it is jammed solid. Common fault.
Hi,
Slightly embarrassed about relisting this thread as time has passed, but I still haven't resolved my blower issue ( too much to do, not enough time etc etc) I did check my drain plug, and as photo just about shows, there wasn't one anyway! So any further thoughts very welcome. With colder days and misty screens fast approaching , I need to be a bit more proactive now! Thanks Rob ![]() Click image to enlarge |
