![]() | Home > My Defender > rear door windows |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
![]() Click image to enlarge So after fixing the rear door locking and adding some dynamat while I was at it I'm onto the next rear door and found more broken fir fixings that had previously been repaired but disappointing is the window sider Does only the rubber slid near the door handle sit in a metal channel? And I wonder how the other channel got a hole in it (causing the window not to go up /down smoothly) and the door bent? Can the rubber be replaced? ![]() Click image to enlarge ![]() Click image to enlarge |
Managed to reshape existing slider and working fine....putting back together now with glued fir trees and dynamat on door panel.
