Home > In Car Electronics > How much for a switch
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
Just looked at a switch to drop into the blank on the 60 puma for some front spots.....£56 quid off ebay....are they serious??!!! Anyone know of a cheaper solution? And i dont mean a two quid switch from halfords either!
Post #350619 9th Aug 2014 7:29pm
gilarion
which switch! What do you want the switch to control?
Post #350622 9th Aug 2014 7:32pm
Aux lights one I'd imagine?
LR prices vary greatly, a centre dash used to cost about £60 now £200. Shocked
Post #350623 9th Aug 2014 7:33pm
Jonno1968
Two spots on the front 100w each. I bought a wiring loom and relay with switch already wired up. One problem is imdont know which is the earth coming out the back of the lamps...white or black. .?
Post #350624 9th Aug 2014 7:33pm
Black should be the earth just by it's colour.
Post #350627 9th Aug 2014 7:34pm
Jonno1968
I thought that but was only 60% sure! Thanks.
Post #350629 9th Aug 2014 7:36pm
gilarion
usually its black for earth, use a power probe to determine it though or just connect to a 12 V supply to determine which is earth, cant do any damage if you have a fuse fitted.
Post #350631 9th Aug 2014 7:37pm
Unless they are LED which from your description I don't think they are then it doesn't matter.
Only LED are polarity sensitive.
Makes sense though to get it correct though, quality of work completed and all that.
Post #350633 9th Aug 2014 7:38pm
munch90
a lot of lights use white as earth , like towing electrics
certainly a lot of led lights do use white as earth
but I would guess spots would use black , but only a guess depends a lot where there made
Post #350634 9th Aug 2014 7:40pm
munch90
Post #350638 9th Aug 2014 7:42pm
