Home > Technical > crankcase sensor heat shield
Caterham
just wondering if anyone is aware of any potential issues with the cc sensor not having a heat shield in place.
mine aint there and gather its not the easiest thing to get at to replace - should I bother?
Post #350151 7th Aug 2014 2:58pm
I haven't had one for the last four years and 120,000 miles, doesn't seem to be a problem. One less thing to rattle!
Post #350164 7th Aug 2014 4:09pm
Caterham
Excellent.....one less thing to worry about..
Looking at workshop manual sensor tells ecm crank position at start up and that's it.
Thumbs Up
Post #350181 7th Aug 2014 5:27pm
bga86
2015 Defender 90 Puma 2.2 HT Fuji White
If you've had a clutch then it will have been left out when the gearbox was refitted, they can be a pita to refit
Post #350187 7th Aug 2014 6:18pm
Happyoldgit
Once they've been unclipped they never seem to fit back snugly even if the bracket is tweaked, the one on my last 2.4 rattled and buzzed at high revs.
I see you're still searching for problems ...CV joints ok at the mo? Wink Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #350206 7th Aug 2014 7:51pm
Caterham
Shocked cv joints!!
Have x2 p2562 faults. Bearing in mind the turbo was replaced I wonder whether the wiring has been the issue all along and it's starting to 'show it's face' so to speak.
Post #350400 8th Aug 2014 7:27pm
