![]() | Home > Off Topic > Has spider season come early |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
I have more on my car than usual inside and out
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
i had to move a stack of firewood yesterday hundreds of the
![]() ![]() my youtube channel |
You mean there's an off season........?
Ellisboy Member Since: 13 Oct 2013 Location: Deep South Posts: 539 ![]() ![]() |
There's always a spider or two in my Defender!
I think they're part of the build at Solihull they keep the car held together
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 ![]() ![]() ![]() |
Thank your lucky stars they're only little blighters. I found this one crawling up the back of my neck on a recent trip to Australia.
![]() ![]() Click image to enlarge 2015 90 XS CSW TDCi - Beautiful 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 ![]() |
You were lucky, that looks like a Brown Recluse spider, if it is one the bite is highly venomous. 110 Hardtop
Gawd, I hope not, I was told it was a Huntsman!
I did a bit of tree felling while I was there and there were loads of them hiding underneath the dead bark and in nooks and crannies. If it is what you say I did have a lucky escape. 2015 90 XS CSW TDCi - Beautiful 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
I am no David Bellamy (people over 40 will know)
Andrew james Member Since: 02 Jan 2013 Location: Awliscombe Posts: 88 ![]() ![]() ![]() |
Definitely a huntsman. A Brown Recluse only grows to around 20mm. A huntsman grows to around 300mm!!!!
I bet you ![]() ![]() |
Aha, a huntsman it is then
![]() Still it must have been a real shock ![]() |
Lol, it wasn't the one that crawled up my back that startled me as I knew by then that they were around. However, this one was the first one I encountered and did make me jump a bit! It's the size of 'em that gets you!
They were pretty dopey and slow but I should think they'd be quite intimidating if they scurried towards you. ![]() Click image to enlarge 2015 90 XS CSW TDCi - Beautiful 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
size 10 needed
Mother superior Member Since: 05 Aug 2013 Location: Surrey Posts: 506 ![]() ![]() |
Blimey, that is a big bu66er. It's a lot bigger than the spider that was fitted to the 110 when I brought it so it must be a 130 spec spider
Wes Oh woe, oh woe My crusty old landrover, It will not go. |
