Home > Puma (Tdci) > ABS brakes
Eduardo
ABS brakes
Hi guys
Just a quick question
It is possible for a MY2007 add the ABS brake system,
is it apossible work or it is a PITA?
If can do the cost will be prohibitive and will be better to buy a new one?
I need to change my ECU programming?
Regrettably most of the MY07-MY12 defenders sold in Chile doesnt have it Sad
Cheers and thanks again for all the help Eduardo
Post #350209 7th Aug 2014 8:59pm
jimbob7
Need front axle,rear rotator rings x 2 £300,(EACH, or £600 for 2 Wink ) abs modulator,£1500,new master cylinder £180,new brake servo £dunno, 4x abs sensors oem, think theys about £80 each,ecu £300 (ish),modify or buy new dash binicle for abs/tc lights).Thats just off the top of my head,oh, and a forth brake line running to the rear.Guessin buying second hand isn't an option?? Pov.spec,ftw. 2006, 110,TD5.
Post #350308 8th Aug 2014 10:14am
munch90
+ all the wiring
not something I would like to do or even have done by a specialist
Post #350317 8th Aug 2014 10:39am
Eduardo
Thanks,
That was my initial suspiction. Better buy a new one instead Neutral
Cheers Eduardo
Post #350343 8th Aug 2014 12:48pm
