Home > Wheels & Tyres > Argh - Decisions Decisions |
muddybaldboy Member Since: 09 Apr 2012 Location: Ruthin Posts: 395 |
I've got a set of 5x 18s and adaptors (brand new adaptors) available (actually got 7 if you've got a Sankey)
Looking for £380, leaves £1120 free for tyres He who dies with the most toys...wins! |
7th Aug 2014 10:52am |
newhue Member Since: 28 Apr 2014 Location: Brisbane Posts: 351 |
height over width any day in my world. But if you after the look then the fattest thing that will fit under the guard.
http://tire-size-conversion.com/tire-size-comparison/ My Defender and travels |
7th Aug 2014 11:29am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6046 |
I've run both sizes on my defenders.
IMO... if you're going to be going "off road" proper, then 255/85's have the edge (about an inch taller) If just general laning and road work, 265/75's look good and handle well. don't get me wrong, the 255's handle just fine, and if you've got a standard 1.4:1 t/box then gearing is perfect (see you have a puma, which should have a 1.2:1 t/box but lower ratio 1st for better pulling away) but for more spirited road handling the slightly smaller 265 would get my vote... but it's only a marginal thing. |
7th Aug 2014 11:50am |
+1 for 255/85 R16
I just there were more brands/patterns available He who dies with the most toys...wins! |
7th Aug 2014 1:22pm |
Bionicmunky Member Since: 15 Oct 2013 Location: High Wycombe - Buckinghamshire Posts: 108 |
Ok,
Consensus in the thread and the forum seems to say that 255 is the best choice for a bit of everthing. Now how about getting that wider stance? or should I just leave it at the tyres and spend the budget on other goodies (I have been allocated spend from Mrs T and therefore want to use it ) JT |
7th Aug 2014 2:44pm |
I also had a set of 285/75's on the project90-3 that I recently built.
They were fitted to standard HD steel (aka Wolf) rims, no spacers. Were great until the first puddle you go through, then you can't see anything out of the side windows. |
7th Aug 2014 3:26pm |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 |
I have 235/85s on sawtooths (road use) and 255/85s on modulars (playing). The last ones look more aggressive, but on the road you feel the 235s are more nimble.
I do a lot of miles, but still greenlane at least once a month for one or more days. So I exchange the wheels for that. It's safer and you don't wear out the expensive BFG MTs on the road, so they always have plenty of thread left. Good time to inspect/clean your brakes as well. The 255s on steel rimms are a lot heavier and are, because of their larger diameter harder to turn around (not a problem in low range, not really in high either but you feel a difference) so I guess switching to 235s for road use also saves the drivetrain in the long run (maybe). One would also save the expensive sawtooths from scratches doing this, although for me it's too late now. One lesson I learned however is that when replacing your wheels, put them on exactly like you took them of. Mark them for that. I did not do that with my old wheels and got a tremor I will probably only loose when they are re-tyred, which thankfully is soon (Did +40k miles on my original Wranglers). Will be replaced by a road tyre, probably BFG ATs or again Wranglers which served me well. Or maybe Grabbers or Continental Cross, or... not descided yet. I think most tyres within the same range (winter or summer) are pretty much the same for my use, so I will look at re-sale values when they are half way through. If you go 255, there aren't much choices... I will post some pictures when I have the time, so you can see the difference between both when fitted. Last edited by zone30 on 7th Aug 2014 4:11pm. Edited 1 time in total |
7th Aug 2014 4:07pm |
You know I like puddles Jamie.........
Click image to enlarge |
7th Aug 2014 4:09pm |
235 Sawtooths
Click image to enlarge 255 Modulars Click image to enlarge |
7th Aug 2014 9:23pm |
235 Sawtooths
Click image to enlarge 255 Modulars Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
7th Aug 2014 9:47pm |
