![]() | Home > Puma (Tdci) > 2.2 intercooler hose split - driveline smoothness |
| longman Member Since: 08 Nov 2012 Location: derby Posts: 11
Hi,
The symptoms you describe are just like mine, juddery at low speeds and a light throttle. I'll check out the intercooler hose to see if this is the problem. Thanks for the post. Andy |
| Hifonics Member Since: 11 May 2010 Location: Bridgwater Posts: 63
The intercooler hose is a recall, I just had mine replaced during its first service.
| Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 617
I had the same issues:
http://www.defender2.net/forum/topic21673.html |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
Hose problem is common but I don't recall any previously mentioning drive line smoothness....?
How is that related - anyone? .....i need to check mine even though mine is a 2.4 |
| PrivateB Member Since: 02 Dec 2013 Location: Lincolnshire Posts: 34
Just had mine replaced when it went in for a fuel leak - gear changes are so much smoother now - Loved it before - Love it even more now....
Not doubting what you are saying but should we be surprised that gear changes are smoother and if not then why ie what causes the pipe to impact on gear changes?
Defender2495 did you have the engine mil light on or you just did the recall? |
Unsure as to why the hose change has had an impact on gear changes - as the turbo is doing almost nothing at those revs? - a great improvement in driveability though. No MIL or recall notification - they just changed it whilst it was there for the fuel leak.
to my mind that's bizarre
would be interesting to understand how things have changed.....I wonder if the difference is the result of a map update which was done at the same time but perhaps not mentioned? good to hear its going well which is the main thing. |
| dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173
Mine had blown couple of months ago and replaced. It was the left hand side hose. Its not cheap either to get couriered to this part of the world from UK.
