![]() | Home > Maintenance & Modifications > Drilling the sills....where!?? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5998 ![]() ![]() |
I would just sikaflex them on. No holes.
Andy |
Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245 ![]() ![]() ![]() |
Sikaflex?? Whats that?!
Very strong PU sealer/glue, in a mastic tube. Good stuff.
Andy |
Ok thanks...where can i get it from....halfords?!
Motor parts shop, eBay, Amazon. Tigerseal is another version.
If you go down this route dont use too much as you have gaps between the CP & Panel
I would use silicone kit (not sure how it is called in the UK) It glue well and the good thing is you can get it off without damaging the paint. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
If you rivet it on there will be gaps between the two items, and if you use silicone it will have a terrible effect on any future painting
![]() Andy |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
The chequer plate on my 110 has some sort of foam filler pad behind it to eliminate the gaps...
