![]() | Home > Technical > Td5 engine thumping noise anybody experience of this???? |
| Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461
Yeah I would try and avoid using it except for real necessity.
By the time I got to the 3rd paragraph, I was also thinking duel mass flywheel. My experience with TD5s has faded in recent years, but I've heard a lot about the DMF. So the flywheel was replaced 10,000 miles ago, or something else? I assume they will drop the gearbox down to take a look at the flywheel, but I guess just do what IRB says and check the end float in the meantime... 1998 110 300Tdi White Hard Top |
| amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452
Thanks interlet for your reply
Yes I have edited post now |
Update,
Have as Ian suggested checked the end float on the crank shaft. I used a bar behind the crank pulley against the steering bar. There is the ta very slight knock as you lever the bar against the crank pulley but not what I expected. I'm really puzzeled to know what to do. I suppose the dmf I fitted 18mths ago could have been a bad one and be giving these symptoms? |
| kevinf Member Since: 12 Apr 2011 Location: sheffield Posts: 55
mine has had similar problems after a recent gearbox removal,where i also fitted a x brake turned out the hand brake cable was vibrating on the seat box and still is to some extent but now not as bad i would try removing the hand brake cable and testing the vehicle before pulling out the gearbox etc
hope this information isnt too late, just read the post after being on holiday! kevin |
Well I know it's been sometime but another update....
As I thought the fault was with the flywheel I removed the gearbox to investigate. I was hoping to see something obvious but all looked ok until I investigated end float in crank by holding the flywheel and pulling and pushing it. The video of me doing this is below.... This is where my knowledge runs out. Feeling pretty fed up right now Is it worth trying to fix this engine???? Anybody done it??? I Have never took and engine apart before?? Any help very much appreciated Last edited by amondeggs on 10th Sep 2014 10:58pm. Edited 1 time in total |
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
saying,"video is private",my sympathies anyways.
My mistake with the video
should be working now |
| v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 455
Its hard to see from that angle but I am assuming that the movement you are having is the crank moving back and forth and not one piece of the flywheel moving in relation to the other?
It's not too much of a job to drop the sump off (and stiffener plate maybe) and I would have a look in there to see whats happening. I suspect that if you dropped the bottom off you might find something in there. Dave |
When moving the flywheel I thought that it may have been the flywheel itself but alas I think it is the crank itself
At the weekend I will remove sump etc and have a look I suppose when you say you may find something by that you mean the thrust washers ??? If i do is it as simple as refitting them??? Thanks for your comments |
It's going to be hard to say to be honest. From memory the sump is a doddle to get off and i'm not so sure about the bracing after that, I seem to remember that it's with the oil pump.
I will have a look at the workshop manual and see what the thrust washer arrangement is.. Dave |
.......had a look at the manual and it seems that there are two thrust washers, one either side of the centre bearing of the crank.
Even if both of those were missing it still doesn't seem to account for that amount of movement. It might just be the angle of the video or something. Is the engine in or out? The only way you're going to sort it out is to fire the bottom off the engine and I reckon the problem will present itself. I fear it may not be good news though, I hope that's not the case. Dave |
| wizz80 Member Since: 06 Dec 2012 Location: north devon Posts: 38 |
Have you checked the crankshaft pulley ive replaced several of them they can make some strange noises
| Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812
I haven't got a DMF to hand...
But take the flywheel off and check if the crank itself moves. If you have no end float on the front, but you have at the back it's either the DMF or a snapped crank. IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Dave thanks again mate for your help
Think flywheel off next and then possible sump as you suggest wizz 80. The front crank pulley and damper was replaced very recently and as new Ian thanks again mate I owe you a few beers If it turns out I need an engine ???? Anybody got a good one they want to sell????? |
