Home > Maintenance & Modifications > Front springs for winch
ibexman
Will I need new springs if I fit a winch and bumper Whistle
Post #349716 5th Aug 2014 7:54pm
roel
I use the same springs in the front than the standard rear springs 275 lbs/inch?
With the standard spring rate I hit the bumpstops very often. Roel
2003 90 Td5 (2009-now)
Post #349747 5th Aug 2014 9:03pm
Waldo
Pretty sure I'm running standard springs on mine and I've just remounted my bumper with no perceptible change in handling or the way the vehicle sits.
Will Defender 90 XS TD5 (03 Reg)
Post #349750 5th Aug 2014 9:09pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
When I fitted a winch to my former 300 Tdi the front end dropped by an inch or so so I fitted standard 90 rear springs, apparently these are the same as heavy duty front springs. Ride height was restored and you hardly knew the extra weight was there. 2005 Td5 90 XS
Steve
Post #349760 5th Aug 2014 9:40pm
jst
you will get away with std springs but they will sag quicker with time due to extra weight. depending on usage you will prob get 3-4yrs from them as they are.
when the time comes you can always fit 90 HD rears in the front when it does sag Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #349764 5th Aug 2014 9:46pm
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
I measured the height of my wheel arch before and after fitting and there was no difference but that said i didnt re measure after driving. The post before me may have a point about increased sag/wear over time but i think its so marginal that it could depend on lots of other driving wear and tear.
Post #349775 5th Aug 2014 9:54pm
jst
it also depends on what winch and rope is fitted. Cheers
James
110 XS Utility
90 Puma Hardtop
Post #349776 5th Aug 2014 9:56pm
My 110 DCPU has a D44 winch bumper (heavy) with a Superwinch Husky with steel rope and is on standard springs with no problems at all.
Post #349793 5th Aug 2014 10:35pm
landy andy
My 110DCPU with D44 heavy winch bumper, goodwinch and plasma, is on standard springs , and is sitting noticeably lower.
Andy
Post #349805 5th Aug 2014 11:00pm
New 26miles old
With OME 2” Lift Springs Loaded
Empty but with Winch and Ordnance draw in the back
No Kit and OME 2” Springs the day she went
Post #349840 6th Aug 2014 7:24am
roel
I guess your winch bumber and winch with steel cable will easily be 100 lbs heavier than your standard bumper so with standard springs 225lbs/inch each It would have gone down about a quarter off an inch.
I think my set-up is a bit heavier and the height was not my main problem. The problem was charging up a hill like this:
At the start off the hill I hit the bumpstops hard with the standard spring with the 275 lbs/inch springs that is a lot less. Roel
Post #349843 6th Aug 2014 7:37am
excossack
What did you decide on? I am looking at new springs and shocks for my 110 with winch fitted with steel wire. Most months I carry kit in the back mainly for car rallies(tools, extinguishers, recovery gear, chains etc) and tow a Harvey frost crane 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #350996 11th Aug 2014 1:54pm
