Home > Technical > TGV - snapped belt
jst
TGV - snapped belt
just after an opinion really, belt snapped on my TGV at about 2200rpm. 4 push rods broken and one rocker snapped.
Should i pull the head to check valves?
new rocker shaft?
TGV is 2.8 ver of the 300tdi. i am guessing as valves are direct overhead that i could of got away without damaging them? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #349674 5th Aug 2014 4:01pm
jst
forgot to add, front end is back together less front cover, just pondering whether to strip further whilst i await rocker arm. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #349675 5th Aug 2014 4:02pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
I'd want to take the head off to check that everything else is ok!
Post #349679 5th Aug 2014 4:37pm
bga86
2015 Defender 90 Puma 2.2 HT Fuji White
No, it will be fine. Had a 300tdi that snapped a belt last week, bent all 8 push rods and snapped 2 rockers, despite the customers friends and family telling him it would definitely have bent valves etc I fitted a new belt new rods and rockers and it fired first turn of the key, done 4 or 5 like this now and not seen one damage valves yet.
Post #349707 5th Aug 2014 7:25pm
jst
i have heard 50/50 either way. with overhead vertical valves i am thinking it will be ok.
just realised i need more parts now! typical - need the bolts that adjust down onto the push rod, had a bent one i didnt notice! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #349766 5th Aug 2014 9:48pm
As the bottom of the valves are parallel to the piston crowns, then you shouldn't have any bent valves.
Just get a piece of wood/hammer handle and push each valve down, check it's free to move and doesn't have any tight spots, and pops back up again as soon as you release the piece of wood.
I've had several belts snap, 200 and 300's, and (touch wood) never had a bent valve... not to say that it couldn't happen mind!
Post #349859 6th Aug 2014 8:11am
jst
cheers Jamie, will do Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #349927 6th Aug 2014 2:03pm
jst
its all back together, two new valve adj screws, one rockers shaft and one rocker plus belt - seems i was lucky goes well again now, thank you all for the advice. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #350046 6th Aug 2014 10:41pm
