![]() | Home > Maintenance & Modifications > Axle Breather Tubes |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 ![]() ![]() ![]() |
Hi Folks,
Where do they terminate?? One end is connected to the axle, but where does the other end normally get secured (factory position)? Am looking at extending or replacing and routing into the engine bay so it can run up the snorkel side. In the engine bay, I can see two hoses, which as I understand is the g/box and transfer box. Cheers Andy |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
Near the EGR, two looped ends (think walking stick shape) between the EGR and OS wing. Near a black bracket.
Hi, do they terminate into the air box?
I know that the two "hooked" ones in the engine bay are the T/box and g/box.......but maybe I'm wrong? Cheers Andy |
I always thought they were axle breathers, you can trace them from underneath.
Ok, fair play I may be wrong
![]() So where are the g/box and transfer box ones located? Cheers Andy |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 798 ![]() ![]() ![]() |
On my TD5 the G/box and T/Box breathers appear behind the head- a pair together.
The axles, Front one appears slightly inboard and below the airbox, the rear was tucked up under the rear seat box somewhere. Chris |
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 ![]() ![]() ![]() |
The rear axle one is usually located in the back of the N/S/R wheel arch, and I think it has a one-way valve on it. Pete
2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
Is that not the breather from the tank?
Chris |
