![]() | Home > Technical > Converting my 90 to rear disc brakes |
I think the easiest and cheapest is to take an disco rear axle.
It should be a straight fit. The only thing I am not sure off is the brake force regulator. That is located below the brake mastercylinder on the chassis I believe. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6216 ![]() ![]() ![]() |
Just stick on an ex disco or 90 rear axle.
Don't think you can convert the axle, as there's no tabs to bolt the calipers on to (and the Salisbury bracket won't fit the 90 axle) You should be able to pick a whole axle up for not much money. |
uncas Member Since: 22 Nov 2012 Location: Wentworth near Rotherham Posts: 340 ![]() ![]() |
![]() Uncas |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Ok are the defender 200 tdi and disco 300tdi drive flanges interchangeable
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
D'OH! forogt about that! Yes, once you get the disco 3 pronged flange off (undo the bolt in the middle, get a puller or slide hammer and pull the flange off), you'll need a small spacer to fit in behind the flange. Ashcrofts sell these, although sometimes they come with the flange (if you've bought a new one). Might be one in your existing diff. Another thought.... when you pull your old axle off, have a check at the diff that's in it... you might be lucky and have a 4pinion HD diff (with 24spline halfshafts), in which case you'd be better off swapping the whole diff over. |
Nice one cheers i will have a look and see what both diff's are like once i get the other axle
Graham fit a new seal with the flange. 300 tdi axles are 34 spline.
Uncas |
Nice one cheers
24 spline |
You beat me Diesel Jim. Fat fingers typing on a little phone. I did mean 24 spline
Uncas |
