Home > Off Topic > Roof rack over hang
excossack
Roof rack over hang
What is the max over hang you can have on a car? I.e if I wanted to transport say a 20ft scaff pole on the roof rack it would over hang, but whats the max it can do? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #348467 30th Jul 2014 9:48pm
Rear projections: Up to 1m overhang, no special requirements. Between 1m and 2m, ends must be "clearly visible". Between 2m and 3.05m, ends must be marked with approved marker boards, side marker boards required. Over 3.05m, two clear days notice to police, full marker boards, plus an attendant required.
Front projection: Up to 2m, no special requirements. Between 2m and 3.05m, marker boards and attendant required. Above 3.05m, same requirements as for 3.05+ rear projection.
Remember these are projections beyond the ends of the vehicle (or trailer) on which the load is carried, so your scaffold pole could extend 2m in front of the front bumper and 2m behind the vehicle. Loaded sensibly a 20' pole should be no problem, but you may need to support the front.
Post #348488 30th Jul 2014 10:42pm
leeds
Like a lot of things not a straightforward answer.
Have a look here
Assuming a 110 of overall length 4.6m then 8.6m is possible
OK inform police have attendants etc then 10.6 m possible.
20 feet = 6.1 metres so on a 110 or a 90 no problem. However make sure ends are clearly visible. High vis jackets are good and try to balance overhung out.
Brendan
PS Ooops BW types faster then me Razz
Post #348491 30th Jul 2014 10:47pm
A quick read of the C&U regs suggests also that if you had a rear-overhanging load on your roofrack and hitched a trailer on the back, even though the load is not supported on the trailer, it would be the rear projection beyond the rear of the trailer that matters, not from the vehicle.
Remember whatever you do it must not present a danger to anyone and must not overload the vehicle.
Usual disclaimer applies.
Post #348498 30th Jul 2014 11:02pm
excossack
Cheers chaps. Looks like a 20ft scaff pole is doable with a 110 Smile (with the addition of some hiviz markers either end)
Now, just need one more and plan will coming together Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #348726 1st Aug 2014 9:21am
