Home > Puma (Tdci) > Standard dash type switches to fit in existing holes
ian4002000
Australia 2012 Defender 130 Puma 2.2 HCPU Coniston Green
I have a 2012 130 and I have many spare switch spaces in the dash. Where can I get blank switches to put in the standard holes ?
I have not seen any standard switches for sale.
All help appreciated !
Post #348345 30th Jul 2014 8:11am
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Some are surprisingly expensive...
Post #348348 30th Jul 2014 8:49am
PaulMc
Re: Standard dash type switches to fit in existing holes
The standard range of switches are available from a main dealer, or Genuine Parts seller, such as Rimmer Bros, Britcar, etc... (in the UK)
http://lrcat.com/#30/4/44951
Not shown above - Auxiliary Lights switch YUG000540LNF
There are no 'blank' switches available - but, these can easily be made-up, by using a Heated Seat switch YUF500150LNF - with the 'Heated Seat' front removed and replaced with the front off of the blanking switch AMR5432
The blank front can be modified, with a 2.4mm hole, so that the 'tell-tale' LED can be used, like this -
There are also some custom switches available a bit nearer to home for you -
http://www.expeditioncentre.com.au/online-...wards.html
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #348355 30th Jul 2014 10:26am
