Home > Maintenance & Modifications > OAT antifreeze/Coolant in a TD5
timtom1
United Kingdom 2001 Defender 90 Td5 CSW Alveston Red
Hi,
My antifreeze is low and its a pink colour, I've been and got some ready mix OAT antifreeze as its the same colour.
Is it OAT that goes into a Defender 90 TD5? 2001 90 TD5 CSW Alveston Red Manual
Post #348245 29th Jul 2014 5:26pm
grumpy old git
It's OAT in my Disco 2 so it will be. There was at some stage a plastic collar around the filler on the header saying OAT only.
Post #348267 29th Jul 2014 6:56pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Just been to dealer and bought OAT coolant.
Pink in colour and definitely right stuff for TD5. Thumbs Up
Post #348268 29th Jul 2014 7:07pm
timtom1
thanks guys, I have also just found it in the Haunes manual Smile
I've got a bit of a seep from near the radiator or thermostat don't know what part it is but think the pipe might need looking at.
Its funny as Halfrauds says the blue stuff for Defenders 1983 to 2007. That would have messed things up Rolling with laughter 2001 90 TD5 CSW Alveston Red Manual
Post #348291 29th Jul 2014 9:07pm
Tommo
As far as I know it has always been pink...but also has to be OAT.
I am changing mine this w/end (first time Shocked ) so am slightly anxious I don't encounter a problem!!
Anyway good luck with yours
Tommo
Post #348432 30th Jul 2014 7:31pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Don't quote me but I believe the eu2 td5's are blue and the eu3 pink,
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #348482 30th Jul 2014 10:26pm
timtom1
I'm sorted thanks guys it is Pink 2001 90 TD5 CSW Alveston Red Manual
Post #348519 31st Jul 2014 7:42am
Tommo
Just changed coolant. Took out just under 6.5 litres and now waiting for engine to cool to top up expansion tank. Easy enough apart from access to the clips which were a Censored
Post #348960 2nd Aug 2014 11:27am
Tommo
Mmmm...took defender for a 8 mile drive and when I got home checked level in expansion tank and it appears to have lost about half of coolant level. No obvious leaks to naked eye Sad
Will properly check tomorrow, is it usual to have to top up again?
Tommo
Post #349023 2nd Aug 2014 4:33pm
munch90
yes , keep a check on it for few days as it may have a air pocket somewhere
keep topped up wait for it to level out then check as normal if it doesn't then check for leaks
or if its a big drop check for leaks straight away !
sometimes if you got a weak spot changing antifreeze will cause the weak spot to start leaking
Post #349026 2nd Aug 2014 4:53pm
Tommo
Thanks Munch90.
Will keep my eye on it.
Post #349056 2nd Aug 2014 7:26pm
grumpy old git
Heater on full and the windows open next time you go out should clear any airlocks Thumbs Up
Post #349072 2nd Aug 2014 8:40pm
Retroanaconda
Having the heater on or off makes no difference to the water flow. It's not like some cars where there's a water valve that is opened, the heaters in these Defenders are permanently flowing with coolant.
Post #349074 2nd Aug 2014 8:44pm
munch90
they do have heater control valves that control flow of coolant though the heater on tdci
Post #349085 2nd Aug 2014 9:41pm
Retroanaconda
But this thread is about a Td5 Smile
Post #349168 3rd Aug 2014 10:21am
