Home > Maintenance & Modifications > hand brake tricks
Page 2 of 4 <1234>
munch90
there was a recall for oil contaminated shoes that was caused by the seal
search p022
Post #346514 20th Jul 2014 4:16pm
Caterham
Recall was done thanks mate.
Post #346515 20th Jul 2014 4:20pm
munch90
might be bit like mine they done on a 93 k-reg 90 I had that was under warrenty and they left the nut loose it went from a dribble to a torrent after they "fixed" it
good ole main dealer workmanship first and last time I bothered with getting anything done under warrenty !!
Post #346519 20th Jul 2014 4:31pm
K9F
Shame your 'recollection' isn't as good about the subject matter. Cool
Caterham,
I've already seen the inside of your drum and the marks from the last time you took it apart 14 months ago. This is not fresh news. Why not continue one of the last two threads you started on exactly the same subject within a month of each other?
Thud
http://www.defender2.net/forum/topic20629.html?highlight=drum
http://www.defender2.net/forum/topic20534.html?highlight=drum If you go through life with your head in the sand....all people will see is an ar5e!!
Post #346544 20th Jul 2014 6:13pm
munch90
ah I didn't know this was a regular thing !
Post #346547 20th Jul 2014 6:28pm
K9F
It is indeed see here: Thud Thud
http://www.defender2.net/forum/topic29779....surrection
Shocked
Munch you could have spent the day doing something proactive for yourself instead! I went to the beach with my two daughters......Same trap I used to fall into. Not any more without a search.
Thumbs Up Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #346548 20th Jul 2014 6:33pm
munch90
don't worry Ive not been waiting by computer , just got out the pool with my daughter
but nice to help out with problems , if only they were real problems Rolling with laughter Rolling with laughter
Post #346551 20th Jul 2014 6:40pm
K9F
Thumbs Up Whistle Thumbs Up
It is indeed nice to help others.....especially when they need it....the thanks afterwards I find quite gratifying. Spending other people's money though.....that's even more gratifying I find.
Cool If you go through life with your head in the sand....all people will see is an ar5e!!
Post #346554 20th Jul 2014 6:53pm
Caterham
Embarassed
I'm none the wiser......took thing apart and back together again.....trying to put the retaining pin / spring back on the shoe nearest the passenger side is enough to test the patience of a saint Evil or Very Mad
Anyhow all back together (didn’t really do anything other rebuild and a good dose of brake cleaner) and all really good (for the moment) ?
I suspect one of the shoes for some unexplainable reason has a habit of sometimes getting stuck and not fully returning?
Anyhow for now things seem perfect Thumbs Up
Thank you for the comments.......if they weren't helpful technically they didn't at least keep me smiling when I was getting ready to throw the town in last night with the retaining spring.
Thumbs Up
Post #346799 21st Jul 2014 8:09pm
jst
if it plays up again, you might find it easier to work on when its on the bench, just lift the engine/gbox and tbox out together then you will be able to see the drum and parts inside easily with plenty of space to work in. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #346803 21st Jul 2014 8:18pm
ZeDefender
You have the same work surface as us - are those egg yolks or satsumas in the photos?
Namaste,
Matt Tell someone you love them today because life is short.
Post #346810 21st Jul 2014 8:42pm
Caterham
Shocked
Jst I'm sure you're right but being in capable of drilling a hole in a plastic trim panel I might just give your suggestion a wade berth!
Very Happy
Post #346811 21st Jul 2014 8:45pm
Caterham
Zd - Very Happy .....they're oranges Thumbs Up
Post #346816 21st Jul 2014 8:53pm
ZeDefender
One of them could be an apple... Tell someone you love them today because life is short.
Post #346817 21st Jul 2014 8:56pm
Caterham
Shocked
It's gone!
I hope it's not inside my brake drum Big Cry
Post #346846 21st Jul 2014 10:35pm
Page 2 of 4 <1234>
