![]() | Home > Puma (Tdci) > Water leak in footwell when aircon on |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
the drain comes out above the gearbox
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
There are two seals/grommets to check, one is the water outlet seal under the heater air intake box. The second and most likely is the main water/condensation outlet seal that is located in the transmission tunnel about 200mm in front of the gear lever. Get underneath and shove your hand above the gearbox and you will feel a rubber teat, give it a squeeze and water not milk should run down your arm the latter one you can modify by cutting it to prevent it becoming blocked in future. If you go through life with your head in the sand....all people will see is an ar5e!!
