Home > Puma (Tdci) > Rubber mats |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 |
I have genuine ones in the TD5 - a million times better than the non-genuine rubbish I looked at before getting the pukka mats. Not cheap as you've mentioned, but definitely worth it. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
18th Jun 2010 5:45pm |
you missed a trick there.... I told the sales man I wanted front, middle and rear space mat included in the price ... genuine ones are good.
having said that, the td5 middle row is a single piece, whereas the tdci is 2 pieces joined in the middle .. not sure why ... i prefer the td5 one |
18th Jun 2010 7:19pm |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2075 |
we've got the genuine ones as well - but this is the 3rd waggon they've been in - so are now 16yrs old and still going strong!
The 2nd row ones are split and are better then the one piece in my opinion, as when you've got wet/muddy stuff in the back it is easy to whip the mat out one side than pull the whole thing out - and also if you need something to kneel on to take a peek under the waggon, or to stand on when getting changed after wakling, canoeing or surfing We also got a full boot mat at the same time as the 1st waggon - so that is also a fab bit of kit! I took it out of the last waggon we had after 10yrs of abuse - the carpet looked brand new! no contest - I'd buy them again ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
18th Jun 2010 7:49pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19654 |
i couldn't ask when new because i'm the second owner (57 plate i bought it in feb this year) Just out of interest what is the thickness of the new ones?
18th Jun 2010 8:27pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
I had TD5 90 ones fitted to my Puma as they weren't available at the time but got a new set a week later and i still have the as new TD5 fronts if anyone wants to pick them up from Stirling as i can't be ar$ed posting... £35? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
18th Jun 2010 10:42pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
Full genuine mats as part of purchase.
Well worth it. Mike |
18th Jun 2010 11:28pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Genuine rubber throughout. Seems very strong. The only issue I've suffered from is condensation under the rubber mat (particularly bad in the luggage area). It can lead to smelly carpets. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
18th Jun 2010 11:34pm |
YORKSHIRELAD Member Since: 17 Mar 2009 Location: West Yorkshire Posts: 159 |
Full LR mats all round. They are very good quality. The rear load space one weights a ton!. I think they are one of the few genuine parts that are worth the money......and I'm a tight Yorkshire man
Richard 1963 Series 2A truck cab 2008 110 SW |
19th Jun 2010 9:56am |
harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309 |
I've genuine LR mats front & middle. Very thick and heavy duty, in the XS (don't know if all others are the same) but the lever of the clutch pedal does catch on the mat due to the carpet underneath lifting it further up the footwell.
Rear is two-piece, slight annoyance is that it overlaps more than the links are designed for, but it does the job. I've not lined the rear yet because I'm not sire what I'm doing with it, might buy some cheap rubber to cover it for the time being until I'm more decided. The mats are so togh I'd be tempted to use them to drive on in soft ground in emergencies! |
19th Jun 2010 10:05am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
full gen set 2.4 90 XS
19th Jun 2010 10:15am |
