![]() | Home > Maintenance & Modifications > Checker Plate Dilemma... |
Dale Member Since: 14 Jul 2014 Location: Bristol Posts: 79 ![]() ![]() ![]() |
The insides full of it too. Even the floor in the cab is made of it!
![]() ![]() Click image to enlarge |
Don't forget to spray some etch primer on first or the top coat will flake off before too long.
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 801 ![]() ![]() ![]() |
I have just painted all the chequerplate on the front of my ex EA 110, two light coats of etch primer with a roller to get good coverage followed by two good coats (second one whilst the first still ever so slightly tacky) of satin black machine paint- hoping that if its good enough for digger buckets it should be ok on my wing tops!
From what I read prior to doing it and having painted a couple of bits beforehand the secret is to get a really good key first and degrease really well. I used a fairly soft cup brush on a drill, followed by meths to get a good clean. Black chequerplate on a white 110 is the future. looks SO much better now everything is painted up. Have just done the roofrack to match too. If anyone is interested and I could put up befores and afters. Chris |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 419 ![]() ![]() ![]() |
If you have to have chequer plate, then it's got to be black
