![]() | Home > Puma (Tdci) > terrible clatter then no power SOLVED |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Get the car fully fully hot from a road test before doing a VCV learn and pilot correction.
If it fails jump back to my previous post of its a dead VCV and fit a new one ![]() Turbo arm part number is LR019905 NOTE, after a pcm update the car will want to do a pump learn and pilot correction, if you cant do that now before an update it may cause you problems after also. Pete |
1989964 Member Since: 11 May 2014 Location: cheltenham Posts: 57 ![]() ![]() ![]() |
thanks Pete,
havent done the vcv valve munch, dyou think its likely worth doing?
I think its the first thing I would of done
ill get one then,
I did ask a mate of mine ( who has worked on the transit engines for years ) about this when you first posted and he said that valve as well
so worth a try |
thanks
Just looked in my paperwork. I've fitted 14 since last august and spoke to many more who have had to have them done.
Pete. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
Pete, are you saying in your post at the top of the page that every time you recalibrate the VCV you are using memory in the ECU and that therefore there is only a finite number of times this can be done?
I have a strange recurring fault which throws up the "pump learn not carried out" error code quite frequently, which I don't really understand. If I do a relearn and clear the fault, all is good for a month or so but then it comes back, almost as though it's lost its calibration data (which I don't think should be possible). Because of this I have done quite a few relearns and if there is a finite number I wonder what happens when it's reached. |
does it run any different after pump learn done ?
does it put fault light on dash on ? |
It's been a while since I did the really deep testing and data logging of exactly what was written to what part of the ecu , most of it can be seen in the 2007 puma developement link in my signature.
But that said here is a piece of wording I pulled of Topix in the mean time, can't give more info now as I'm only on the iPad and not my work laptop so don't have an info I recorded here. What I do remember is every time new data was written I could see it in the ecu and every time it was written it was written in a section below the last written part. I also remember having to manually delete some of what was written as I filled the ecu in no time messing around and it would not accept more data until I did this.
Pete. Last edited by bell-auto-services on 14th Jul 2014 9:47pm. Edited 1 time in total |
If the VCV is out of sync before hand yes. Not normally a dash light on for it though. |
Ive ordered one now and will update the thread with the results. hope its good!!
so if no light on , 99% of people would not know anything about if it needed to be done what are the symptoms of how the engine runs if not learnt please ? |
