Home > Td5 > td5 ecu immobilser has activated-panic!
Page 2 of 2 <12
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
as k9f says run a live from the battery to pin 16 on the obd Thumbs Up 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #343071 5th Jul 2014 8:27pm
worzel
United Kingdom 2006 Defender 110 Td5 HT Bonatti Grey
Okay so an update after a week of being mucked about.
Got the td5 towed up to the dealership as I thought this would be the logical thing to do seeing as I'm off to Iceland in a week.
they got it on friday and it was wednesday morning they looked at it after I begged them too, prior to this point I had just been fobbed off.
So they looked at it and said they weren't keen to touch it as the dashboard had a few extra after market items on it.
I can tell you that it is not a working replica of the space shuttle, just a few spot light switches two usb sockets and a volt meter. They argued the point saying that there were lots of wires hanging out where the stereo should be, yes I said that's the stereo wiring.
So I got an auto electrician in who found two blown fuse lines to the 10as. and now it was asking for a code.
But I don't have any fobs, so I can only assume the 10as unit has some how reset itself.
So I as the dealers for some fobs to be programmed on thursday afternoon, on saturday they finally tell me their computer that lets them do it has broken down and they dont know when it will be fixed.
hopefully it will be sorted in a day or two.
Question: can I buy a second hand 10as unit with fob off fleebay and simply replace it with the other one?
the TD5 is a 2006 hard top.
does it have to be a particular type like the 270 or 280?
Post #345010 13th Jul 2014 9:31pm
munch90
if its like the one in the rover cars there coded to the engine ecu
sorry dont know much about the td5 , but someone else will know
Post #345014 13th Jul 2014 9:37pm
worzel
I've seen a few on ebay with fobs, obviously without the fob you'd need to program one, if I just installed a second had 10as how do you go about coding it to the ecu if that's what needs to be done.
I'm getting concerned that the dealership won't come through so I figured I'd try and sort it myself.
Post #345017 13th Jul 2014 9:48pm
munch90
If its same you need to plug it in and force it to learn new code from ecu , ive done hundreds of rover cars butnever played with the land rover as10
sorry dont know what system you would need to program another unit to it
it must be coded thinking about it , otherwise you could plug new unit in and drive away ( steal it )
why cant they code a fob to it or get the eka code
Post #345019 13th Jul 2014 9:56pm
worzel
That's what I'm praying for munch90 but the dealership are proving pretty useless!
I asked for the keys on thursday, but didn't bother telling me their computer was knackered until saturday and they only told me cause I did my nut at them for taking so long and fobbing me off with 'we'll call you in the morning' or 'we'll look at it this afternoon'.
I asked if it could be done at another branch but they couldn't answer that on saturday so I guess I need to go back up there and hang around until I get a result.
There, I feel a little better now.
Post #345024 13th Jul 2014 10:21pm
munch90
I keep meaning to plug my machine in that does rover cars in to defender and see what it does , I can code fobs and match ecus to security unit etc
but never tried it on defender
Post #345025 13th Jul 2014 10:27pm
You'll need something like a nanocom to make the 10AS unit "learn" the engine (or is it vica verse, engine ECU learns the 10AS)
Anywho, it takes about 3 seconds to do... with the correct bit of kit!
Post #345103 14th Jul 2014 1:24pm
worzel
A friend has just said pretty much the same thing, I think the problem is that the ecu is now not reading the 10as.
I will ask the dealership to investigate if they can be bothered.
Post #345147 14th Jul 2014 5:00pm
Page 2 of 2 <12
