![]() | Home > Maintenance & Modifications > Britpart Yellow Heavy Duty Rear Springs |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
I have BP Yellow HD springs with Hi-cap inner helper springs and Super Gaz shocks on my 110 HCP tipper. These were on it when I bought it over 2 years ago now still tows a treat sits a tad high empty but level with a 1 ton of ballast in the back or loaded up with logs.
Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169 ![]() ![]() ![]() |
Got them on my Defender (HD +2) - did 15K miles around Australia on varied terrain, including heavy off road and rough corrugations, with heavy load. Did the job perfectly.
(Teamed up with Koni Heavy Track shocks) Our blog - http://landytravels.com/ Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net |
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 ![]() ![]() ![]() |
I had the yellow progressive HD springs on my 90, and found them to be excellent. Not uncomfortable on road when empty, but will take the weight when you load it up/put a big trailer on. I also had standard rate HD springs on the front though for the winch bumper etc, so it sat level, it may sit quite high at the back if you only have standard springs on the front. Pete
2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Aren't they the same height as standard, just more resistant to compression?
Phatcat Member Since: 01 Nov 2013 Location: W yorks Posts: 98 ![]() ![]() ![]() |
Put these on my truck 2 years ago. Was dubious as they are cheap.
Went heavy duty, due to it having winch, roof rack etc. also for occasional heavy towing. They are standard height yes, but the vehicle sits noticeably higher due to them being heavy duty. I also fitted puma shocks at the same time. The ride is firm, but not too much . ![]() |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
My god!!! Is this a positive for BP stuff???
My flabber is well and truly gasted! ![]() |
Was thinking the same!
Surprised me too!!
Think I may stick them on all round to keep the old girl level!
Yeah they are the same height as standard, but with the heavy duty rating you'll probably have in essense a +1" lift over the stock springs that will have inevitably sagged with age and weight. Mine certainly sat higher, which was a good thing. Pete
had then on 7 year now
Arrived at 1830 by Fedex, rear shocks and springs fitted by 1930
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 688 ![]() ![]() ![]() |
Thumbs up from me also - I had them for a couple of years on my previous 110.
110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158 ![]() ![]() ![]() |
Just fitted +2 s front and rear on top of my 3 inch lift spacers ........brilliant mates had his 0ver 10 year
