![]() | Home > Tdi > How much? |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
For 5k You can find a very very nice 200Tdi 110.
For £4000 you will probably find a good one, which needs a few things fixing. I got mine for about £4000 and have had to replace the rear cross member and am now getting the bulkhead replaced. One comment I will make however, if you have to choose between rusty bulkhead or rusty chassis, go for rusty chassis because it is a hell of a lot cheaper to replace a chassis then a bulkhead. Take your time, there are loads of them out there it is a matter of waiting for a good one and going to see it. if you turn up and they are a bit dubious about you giving the chassis a good tap with a hammer or going for a test drive then treat it suspiciously. Good luck with the hunt! |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
have a look at my thread and see what i got for 5.5k
![]() link at bottom of post ![]() my youtube channel |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8477 ![]() ![]() ![]() |
![]() James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
jason110 Member Since: 13 Feb 2013 Location: United Kingdom Posts: 6 ![]() ![]() |
Thanks guys. It will be a while yet, I'm away with work at the moment. I've been looking for a while, but the mix of trucks and prices seems to vary quite widely.
I have seen your truck g-Mack. I'm pretty envious to be honest! If anybody sees something tidy, let me know! Cheers jason |
Do 200tdi defenders have disk brakes all round? Ta
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5141 ![]() ![]() ![]() |
Yes they do disk brakes all round
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
I thought disc brake rear axle came with the intro of the 300 Tdi. Could well be wrong though. 2005 Td5 90 XS
Steve |
no they don't!! they have drums on rear! well 110 did anyway My 109 thread
Cheers gents! I think I may favour a 300tdi in that case.
My last 110 was a 1986 vintage and I rather despised the drums on the back of that! I know I could most likely ![]() Jason |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
Fitting a disco1 rear axle is a simple mod to get disc brakes on a 200tdi 90. Mine has disco axles front and rear.
udderlyoffroad Member Since: 18 Jul 2011 Location: Bristol Posts: 124 ![]() ![]() |
A disco axle is NOT rated for the weight of a 110. Fine on a 90 though.
Yes, the disc brakes were introduced with the 300 Tdi, however because Land Rover tended to use what they had lying around in stores, and because it's easy enough to convert them with OEM parts (I've done it on my 2.5 NA petrol), it doesn't mean you won't find a 200 Tdi 110 with disc brakes. Just make sure it's not a disco conversion - google images for 'Salisbury axle' - this is what should be fitted. In fact, I'd look for a truck with a good chassis and bulkhead, and if it's not on discs on the rear, budget £300-odd to do the conversion, or £500-odd to have it done... Good luck with your search! Matt Real trucks don't have spark plugs |
/\/\/\ +1
Thanks for that. Top bit of info there.
When something pops up, I'm sure I'll be along with more questions. All I'm after is a tidy wagon I can use locally to bimble around in, with a bit of green laning thrown in. Jason |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3501 ![]() ![]() ![]() |
Sell it sell it (to me). ![]() 1995 110 300TDI 1995 90 300TDI |
