Home > Td5 > Part identification
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Part identification
Hi folks,
Been having a right good sniff around my new defender (new to me).
In the engine bay I see the following component and I'm struggling to identify it......any ideas?
Also it seems like it has the wires disconnected and tywrapped out the way and wrapped in leccy tape.
Any ideas?
Andy
Post #344386 10th Jul 2014 10:52pm
landy andy
Valve for the EGR, does yours still have EGR fitted?
Andy
Post #344389 10th Jul 2014 11:00pm
ROBBONTHEROCK
Ahhh,
No it was removed and blanked off by the previous owner (JE Engineering I believe did the work).
Thanks for the help.
Andy
Post #344390 10th Jul 2014 11:10pm
Little Tom
United Kingdom 2004 Defender 110 Td5 CSW Bonatti Grey
Wanted to identify a part myself tonight and what are the chances, seems like I'm in the same ball park. One of these has started buzzing (maybe just vibration) just wondered if this is going to cause me a problem...
 Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert..
Post #344970 13th Jul 2014 7:43pm
ROBBONTHEROCK
Hi little tom, why have you got two??
If it's for controlling the EGR then two doesn't make sense, unless my car is meant to have two, or the location of the second one has been moved.....
Andy
Post #346393 20th Jul 2014 7:32am
rustandoil
My 2005 TD5 had two valves, just the same as Toms
Post #346394 20th Jul 2014 7:41am
ROBBONTHEROCK
Hi,
A mate of mine was telling me how he hydrauliced an engine during wading despite having a wading kit fitted.
He said that there is a float type valve in the air intake circuit after the wing panel intake point, this closes when the water rises up.
His memory is patchy, except the fact that he had to fork out for a new td5 engine.........
Anyway, my truck came with what looks like a mantec snorkel already fitted, and I'm trying to establish if I need to do anything on the circuit to allow me to run in water (I know about the axle and gearbox breathers).
I'm not planning on taking the car into deep pools of water, but figured if somebody went to the bother of putting a snorkel on then it's worth ensuring it can do what it's meant to be able to do.
Is this the offending valve? It's inbetweeners the wing intake point and the air filter.
Andy
Post #346395 20th Jul 2014 7:43am
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Part 9, which I think is what you are referring to, is a rubber 'dump' valve. If you intend on heavy wading, seal it up, but clean it out first. They aren't a great piece of kit anyway. Some vehicles have them on the bottom of the air box too, I'm not sure if there is one on the TD5...
Post #346420 20th Jul 2014 9:59am
WendyTheTruck
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Andy
Eu3 Td5 engines (post 2002 I think) have an EGR throttle added which is controlled by the second EVRV you see next to the first EVRV which controls EGR valve position.
Post #346434 20th Jul 2014 10:34am
ROBBONTHEROCK
Thanks folks, that explains things.
With regard to the rubber boot on the intake, is it worth replacing that section of pipe?
I have no intention on serious wading, I do think that it should be removed or plugged, especially if it's a weak point if I do go into water!!
Andy
Post #346459 20th Jul 2014 11:59am
appaloosadude
You could replace it, or go with a squirt of silicone.
Post #346466 20th Jul 2014 12:26pm
ROBBONTHEROCK
Hi,
I guess it's upstream of the air filter, so if it a bit comes loose it'll get stopped by the filter.
I could remove part 9 and fill with silicone I guess.
Saves a bit of cash Wink
Andy
Post #346513 20th Jul 2014 4:16pm
