Home > Maintenance & Modifications > Drip from rear diff
timtom1
United Kingdom 2001 Defender 90 Td5 CSW Alveston Red
Drip from rear diff
Hi
I have a drip from the rear diff, looks like its coming from the bolt? not sure I have a jug under it collecting the fluid to see what colour it is..
Any ideas?
Tim
<br>
<br>
<br>
<br>
 2001 90 TD5 CSW Alveston Red Manual
Post #344341 10th Jul 2014 9:08pm
shaggydog
Check your axle breathers they are probably blocked.
Also may be overfull of oil and have what looks like a warn input seal.
Check the breather first though Thumbs Up
Post #344343 10th Jul 2014 9:14pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Check your axle breather is not blocked as this will cause oil to leak when the diff warms up and creates pressure build up.
I changed my pinion oil seal twice before I worked out my breather was blocked ! 2005 Td5 90 XS
Steve
Post #344344 10th Jul 2014 9:15pm
timtom1
I'm very new to land rovers, I do I take them off to check them?
thanks
Tim 2001 90 TD5 CSW Alveston Red Manual
Post #344346 10th Jul 2014 9:23pm
Lou Sparts
If yours is the same as mine the breather pipe comes off of the top of the diff and goes to the offside rear wheel arch and is clipped up high to keep it out of the water when wading, I just unclipped mine and blew down it to check it. Mine was blocked with road dirt at this end and was easily cleaned out. 2005 Td5 90 XS
Steve
Post #344350 10th Jul 2014 9:33pm
jst
pinion diff seal, easy to change, once you have undone the nut! which is not so easy without impact tools if on the ground due to slack in transmission.
seal has gone either way so will need changing but as above when you change it check the breather. you can do the latter by just undoing the banjo fitting on the top of the axle with the black pipe coming off (its on passenger side) and check pipe is not blocked, banjo is not blocked and that hole into axle is free from corrosion. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #344354 10th Jul 2014 9:36pm
jst
td5 is not on the diff casing Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #344356 10th Jul 2014 9:38pm
timtom1
ok thanks I will have a go.
If I undo the seal and replace the seal on the diff will all the fluid come out? sorry for the dumb questions..
Are theses the breather pipes in this video ( at 6.45 near the end) ?
Post #344358 10th Jul 2014 9:50pm
jst
no it wont.
i suggest buying two seals, in case you damage the first one getting it in.
top up after with EP90 to level plug hole on flat surface. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #344366 10th Jul 2014 10:05pm
jst
yes, thats on a salisbury axle though, your looks similar in similar place. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #344368 10th Jul 2014 10:07pm
timtom1
thank you for the advice Thumbs Up 2001 90 TD5 CSW Alveston Red Manual
Post #344374 10th Jul 2014 10:34pm
Agree it could be the pinion diff - but it's not that clear from those photos where the oil is actually coming from.
Before doing something that may be unecessary, clean the whole area to remove all traces of oil and then identify precisely where the oil leak is.
Post #344453 11th Jul 2014 10:37am
shaggydog
As above really. Checking your breather pipes are clear is free to do and very unobtrusive, to do a pinion seal is a bit more involved and can cause damage if not done correctly.
Clean it up, check your breather and oil levels and then see what happens, I wouldn't be surprised if it is just the breathers blocked Thumbs Up
Post #344498 11th Jul 2014 12:54pm
timtom1
I've been away at weekend so I've just cleaned it up and will keep an eye on it over the next few days Smile thanks guys! 2001 90 TD5 CSW Alveston Red Manual
Post #344975 13th Jul 2014 8:12pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Hi,
My 110 is also displaying a weep from the oil plug.
Was planning on finding the breather and checking if it's clear or not.
I have heard there is a mod to extend these breathers into the engine bay, is that correct and is there a kit you can buy to do this work?
Andy
Post #345245 14th Jul 2014 10:37pm
