Home > Maintenance & Modifications > Welding the turbo?
ZeDefender
Welding the turbo?
If I never manage to seal my turbo to the exhaust manifold (I truly am cursed) can anyone think of good reasons why I shouldn't just have the joint welded once and for all? I realise the warranty on the turbo will be void. Would the weld hold up to 1000+ Celcius?
Matt Tell someone you love them today because life is short.
Post #343758 8th Jul 2014 6:19pm
munch90
welding cast iron is not easy , special rods needed normally a pure nickel rod
and the parts have to be preheated
when you you weld it you have to stitch weld then tap it to try to relief the stress from around the weld
chance of 100% seal are very slight
normally when you try to weld cast iron with mig or normal steel rod it cracks round the weld
so really the answer is no
Post #343767 8th Jul 2014 6:51pm
ZeDefender
Bow down Cheers - at least I can scrap that idea then Laughing
Post #343796 8th Jul 2014 8:11pm
munch90
is your turbo still blowing ?
Post #343814 8th Jul 2014 9:03pm
Maybe some sort of u shaped clamp over the flange, especially if it was heated and then cooled to a shrink fit.
Post #343824 8th Jul 2014 9:24pm
Alive Tuning
1000 degrees! Shocked
Post #343827 8th Jul 2014 9:30pm
ZeDefender
Just to be on the safe side Gary Laughing I'm considering fitting a Stack exhaust gas thermometer but I'm not sure it's worth it...
@munch90 - Yep, I fitted the Nakatanenga gasket this morning but there is still a very slight leak (no screaming though) so I'll just have to see how it goes over the next few days.
@Supacat - also my thoughts. I have a "spare" turbo and exhaust manifold to practice on and want to design some kind of gas-tight reinforcement. Tell someone you love them today because life is short.
Post #343872 8th Jul 2014 11:28pm
shaggydog
The weld would but the aluminium casting will have dissolved Shocked
Just a thought, but if your looking at welding it you are looking at some serious work.
Why not try ether going to a exhaust specialist and get a fabricated manifold with a much thicker flange on it to withstand the heat, maybe looking at stainless steel. I make loads of custom exhaust flanges from stainless steel at work and they are all about 12-10mm stainless steel.
That said, that casting should not warp that much. Try taking it to a machine shop and get them to shot blast it to remove the outer skin of the metal and then get it skimmed flat. Most metal stressing is due to the outer few mm of the metal and this could be contributing factor to the warping. We have had sheets of steel at work climbing there way out of the tank due to the stress being released from the material when they are being cut so its not unreasonable.
Post #343873 8th Jul 2014 11:31pm
Cheshire110
just out of interest, what kind of symptoms/problems does a leak cause? down on power? noise? is it a genuine problem or just want it to be perfect? Cheers, David
Post #343874 8th Jul 2014 11:33pm
ZeDefender
Yep - if it leaks badly, I'll have it off, skim it and try again. Hopefully no more warping afterwards Thumbs Up Tell someone you love them today because life is short.
Post #343875 8th Jul 2014 11:33pm
ZeDefender
Just bloody noisy when it starts, then quieter but smelly when it gets worse as the gases get into the cab. Power doesn't seem to be much affected though, even when the leak is bad.
*Edit* but "perfect" would be nice Wink Tell someone you love them today because life is short.
Post #343876 8th Jul 2014 11:35pm
K9F
ZeDefender wrote:
Just to be on the safe side Gary Laughing I'm considering fitting a Stack exhaust gas thermometer but I'm not sure it's worth it....
I don't think it is. It would just be another peripheral gauge cluttering up the cab that you would be constantly distracted by due to your troubled history with the turbo. Unless of course it could be configured to some form of 'shutdown' but that would require ECU reprogramming perhaps?
Don't any of the real time fault/condition readers display any temperatures you could relate to the turbo anyway? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #343889 9th Jul 2014 7:38am
munch90
fit a turbo blower
Post #344075 9th Jul 2014 7:49pm
Roy5695
Search google for v-band clamp. We use these at work to hold exhaust pipes onto jet engines, would do the trick I think...
Post #344157 10th Jul 2014 1:02am
ZeDefender
"Turbo blower" Question
A cooling fan for the turbo?
Not sure a v-band clamp would work as the manifold joint is triangular - also the gap only has to be tiny to give the problem. Has given me an idea though.
On the positive side, the Nakatanenga gasket is holding so far (doesn't quite pass the "spit test" though) and Pete has taken a little off the top end of the remap to save me from overworking the poor girl. When towing uphill, full of passengers at speed, something needs to say "stop"...
*Edit* Mal - I know what you mean. Looking at the Scangauge too much is one of the reasons I only use it for "special occasions". If I fit an EGT gauge though, it will take its feed directly from the turbo housing, so it would be very accurate. Tell someone you love them today because life is short.
Post #344169 10th Jul 2014 6:49am
