![]() | Home > Td5 > TD5 Fuel Filter Housing |
| taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663
Nobody know?
| appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630
I don't know the answer, but will be watching intently, as I believe I have the same jobs to do on mine...
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
There was a thread about this recently but I think the outcome was they weren't interchangeable
Hmm ... I've done quite a few searches and found nothing on that! Don't suppose you have a link?
I did fear that outcome, would just be nice to know difference! |
| Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230
From my investigations the WJN500150 doesn't have the water trap sensor. It also appears to fit both Defender and Discovery TD5's.
It was called fuel filter head part number or something like that (don't know how to put a link up
The water sensor is part of the Filter itself, not sure the 'body'/'top' has any sensor kit on it. If the pictures are anything to believe, then even the later 'body' comes with the filter and water sensor in the bottom.
As I mentioned before, I think mine is past the point where they decided not to fit the sensor any more as mine certainly has no wiring for the sensor to plug into! Even on early TD5's, most people would just stick a new filter on without the sensor anyway as they would often cause more problems than they're worth and the only redundant wiring then is the loom from the vehicle. Nothing on the 'body'? Confusing! Can't see what difference there is as the change came after the EURO 3 update anyway! |
Easiest way is open the topic up, click into the URL bar at the top, ctrl+a, then ctrl+c, then come into the one you're replying to and in the reply box, just hit ctrl+v.
And yes, I have read that one then ... Found that very odd as head only had 1 in, 1 out! |
Right, just had a conversation with Justin at Brookwell's and I must say what a friendly chap.
Initially it went down the official lines of WJN500150/WJN000020, but after speaking with him, I questioned the fact they had WJN000030 listed as fitting Defender TD5 1998-2006, so the whole range effectively. He went off the speak to a colleague and rang me back about 10 minutes later. He confirmed that the 'head' of the housing's were all the same including WJN000020 - WJN500150 - WJN000030, the only difference being the water sensor ... Why this adds over £150 to the price tag I dont know. Thus I have ordered WJN000030 (the only one they stock) which is the Disco II filter assembly, but the same assembly throughout the TD5 Disco II production. I personally believe WJN000020 and WJN000030 are the same, second being the Disco II part number. The WJN500150 is the same head, same filter body, but different water sensor and plug. I will see what turns up and post my findings. Will also strip the new one down to check the valves and internals are the same! If I could afford to order the WJN500150 as well I would have, but after the past 3-4 months of very big bills for the 110, I'm just about wiped out, so I cant afford do do a comparison! Technically though, my old one should be WJN500150, so we shall see! |
| pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500
I have a new one sitting in the shed if your interested never got round to fitting it? 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Which P/N?
No idea part no but pics below
Click image to enlarge Click image to enlarge Click image to enlarge 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Shoot me a PM with how much you'd want as I'd be very interested.
I have the WJN000030 coming anyway, but always good to have a spare and I want to try and work out what's what with them, so an ideal one to strip down and compare (hoping it's a WJN000020, so I can compare with the WJN000030 I have coming and the WJN500150 which theoretically should be the knackered one) |
Pm sent 2008 110 2.4 XS Utility (Hagrid)
| All times are GMT |
