Home > Maintenance & Modifications > Bottom fan cowl 2.2 Puma
2014110XS
2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Does anyone have any idea how to remove the bottom fan cowl? The top comes of easy enough, but does the fan need to be removed to get the bottom off?
Thanks in advance.
Post #343546 7th Jul 2014 7:57pm
2014110XS
Bump, anyone please?
Post #344573 11th Jul 2014 7:52pm
bob neville
Best I can get I'm afraid.
Engine Cooling - ID4 2.2L Diesel - Cooling Fan Shroud
Removal and Installation
Removal
1. Disconnect the battery ground cable.
For additional information, refer to: Battery Disconnect (414-01,
General Procedures).
2. Drain the cooling system.
For additional information, refer to: Cooling System Draining, Filling
and Bleeding (303-03, General Procedures).
3. Remove the cooling fan.
For additional information, refer to: Cooling Fan (303-03, Removal
and Installation).
4. CAUTION: Make sure that all openings are sealed.
Use new blanking caps.
Release the cooling fan shroud.
1. Disconnect the coolant expansion tank hose.
2. Release the coolant expansion tank hose from
3. Release the cooling fan shroud remove the 2
screws.
5. CAUTION: Make sure that all openings are
sealed. Use new blanking caps.
Disconnect the radiator top hose.
6. Release the thermostat from the cooling fan shroud.
7. Remove the cooling fan shroud.
2013 Defender 90 CSW - sold
Post #344610 11th Jul 2014 11:09pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
when removing it from my 2.4 to fit thte 3.2 which is the same it came out atached to the radiator is there a reason why you need o remove it ?
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #344685 12th Jul 2014 12:00pm
Yes I think fan comes off first and then after a couple of other steps lower cowl can be brought up and out.
Removal
and Installation).
screws.
5. Disconnect the radiator top hose.
Post #344719 12th Jul 2014 5:39pm
