Home > Maintenance & Modifications > Galvanic Corrosion
Browjam
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Havana
Galvanic Corrosion
Hi there,
In suspect this has been covered before but here goes.......
I was about to pull the trigger on replacing all of the door, bonnet and tail gate bolts with stainless steel bolts when I came across a short article that came up on my browser that basically said stainless steel bolts will not rust but due to ‘galvanic corrosion’ mild steel items like hinges will start to rust much more rapidly.
Can anyone advise on this and what are their experiences with fitting and living with stainless steel bolts?
Many thanks in advance.
James
Post #343382 7th Jul 2014 10:24am
The usual trick to avoid this is to coat the bolts with ceramic paste such as Duralac. This forms a barrier between the two metals. Darren
Post #343387 7th Jul 2014 10:44am
jimbob7
FWIW,stainless doesn't rust but it does corrode (eventually),not heard that it speeds up the process in other metals tho,every dyas an edukashun,interestin post tho. Pov.spec,ftw. 2006, 110,TD5.
Post #343389 7th Jul 2014 10:47am
Browjam
Cheers,
Pretty obvious I am a newbie to the forum Rolling Eyes
Just looked up Duralac. Looks perfect for the job. Will order the stainless steel screws.
many thanks.
james
Post #343392 7th Jul 2014 10:51am
If it's anything like the Naka stuff it will be anti seize too which really is a must as well.
Post #343397 7th Jul 2014 10:59am
Tiger
Depends how good your chemistry is.
Steel will rust but it will also when combined with water cause a dissimilar metal to corrode. (The Ali) Basically the water and the two metals when in the presence of an electrolyte (water with bits) make an anode and a cathode which allows the metals to change due to a flow of the electrons.
Stainless does this also but it concentrates the process on the dissimilar metal so to speak.
So Stainless Steel causes a stronger reaction in the Ali.
To get around this you can isolate the two metals. (Google Duralac as above, horrid stuff though) This will help to stop the ions flowing or never ever ever get it wet. Thumbs Up
Post #343408 7th Jul 2014 11:19am
leeds
Hi James, apart from galvanic action stainless nuts and bolts can cold weld themselves together know as galling.
We get comments about price of the Nakatanenga stainless bolt kits we sell. Apart from being the only bolt kits having genuine Land Rover door bolt heads they come with a big tube of anti seize paste.
The new version of the stainless bonnet hinges we do come with a small sachet of paste as well.
Now why don't the other suppliers of stainless bolts for Defenders supply the paste?
Brendan
Post #343410 7th Jul 2014 11:42am
SailingTom
Other option is to use plastic washers, for anyone interested this link explains the differences in corrosion fairly well.
http://www.clubmarine.com.au/internet/club...+Technical Defender puma dormobile camper
Post #343414 7th Jul 2014 11:52am
rsms
Slovenia
If it is still the original composition I would keep Duralac off your skin as part of the reason they banned the retail of similar chemicals in sprayable form many years ago (potential carcinogenic). I am using Tef-Gel instead:
http://tefgel.com.au/
http://www.force4.co.uk/7168/Harken-Tef-Ge...Paste.html
Post #343513 7th Jul 2014 6:04pm
