Home > Td5 > td5 ecu immobilser has activated-panic!
worzel
United Kingdom 2006 Defender 110 Td5 HT Bonatti Grey
Hi,
Got a problem and I'm really hoping you can all help solve it.
Basically the red engine light with a bolt through it which I believe is the immobiliser, has just appeared for the first time ever and I can't start it but is it related to what I have previously done which is as follows:
Td5 all great for last two years since I've owned it 06 plate basic hard top no fobs or central locking or alarms.
two days ago got my Nanocom and all worked well.
plugged it in this morning and the nancom didn't fire up ( it does on laptop but not on td5) their support advised me to test cable and the power supply to it is now only about 4 volts so I disconnected it for the rest of the day.
I drove the td5 a few times short distances then noticed my new stereo was no longer working, got home and disconnected to check power supply and fuses, all was fine so assumed it was a duff stereo, then I noticed a faint red light in the speedo and thought 'haven't seen that before' so went to start it and it wouldn't!
Now I have poked around some fuses but all seems normal, I've learnt the ECU has an immobiliser in it but is set to OFF as it's a basic hardtop but now it would appear to be ON,
do you think the nanocom had anything to do with it? I can't even check with it as it doesn't work at the moment.
Or was it me poking about?
more important how do I fix it - off to Iceland in two weeks so starting to brick it a bit!
any help gratefully received.
Post #342645 3rd Jul 2014 10:55pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
i would check your battery or even alternator 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #342665 3rd Jul 2014 11:51pm
K9F
Re: td5 ecu immobilser has activated-panic!
worzel wrote:
......their support advised me to test cable and the power supply to it is now only about 4 volts .
"Don't panic Mr Mannering!"
Fundamentally I think therein lies your problem. Where's the other 8 volts plus gone? Big Steve's suggestion is a good starting point!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #342667 4th Jul 2014 2:46am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
even if the immob is set to off and the alarm is disabled, there's still some handshake between the ECU and the 10AS.
There's still the code and if there's an attempt to swap ECU or 10AS it can suddenly make the 10AS say, hey, the code is wrong and then when you query it, it will say ECU is immob.
Well, like you mentioned you have a nanocom so check there first, if it's really immob, if so, then make the 10AS learn the ECU again and it should be well. The defender has migrated, leaving the owner behind.
Post #342967 5th Jul 2014 8:56am
munch90
if the alternator is faulty it can put the ignition light on very dim even when ignition off and key removed .
normally when the alternator does this there is a short inside that put light on dim and flattens battery
Post #342970 5th Jul 2014 9:03am
worzel
thanks for the advice so far, batteries are all fine think alternators okay but will check, the defender is a standard hardtop and didn't come with and thrills,.
Is the 10AS a box behind the dashboard tt i've been reading about and if so do all defenders come with them regardless and as achuakh says it talks to the ecu, could I have some how dislodged a cable or something when I was rooting around with the stereo cables?
Would like to check it with Nanocom but it stopped getting enough power up the cable the morning the rest went wrong.
Still very confused.
Post #343001 5th Jul 2014 1:43pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
The 10AS is indeed the green box behind the dash/speedo panel, easy enough to remove the panel with 4 screws, one in each corner, the 10AS is a bit more fiddly due to limited access to the securing screws, to be honest though, you shouldn't really need to go there.
I wouldn't have thought it likely that disturbing the stereo wiring would worry it, the wiring to the 10AS connectors is generally pretty secure.
When you say "the battery is OK" have you had a voltmeter on it? does the car still start, or at least turn over at a reasonable speed.
One other point, when using the Nanocom Evo, you should always disconnect the OBD connector first, (the one on the car,) never undo the 15 pin connector between the NC and cable while powered up, I believe this can cause serious issues with the NC where it will need returning to BBS.
Post #343003 5th Jul 2014 2:00pm
worzel
cheers Clive, already aware of the Nanocom unplugging and been careful to follow procedure.
The car doesn't start at all can hear fuel pump and all lights come on as expected but then the red engine light comes on and as I turn the key further the power drops out ( have volt meter on dash)
The car battery is reading 12.1volts.
Seems funny that it happened directly after taking stereo out, maybe just bad timing and I'm barking up the wrong tree?
Post #343004 5th Jul 2014 2:17pm
Clive
Does seem odd, It would appear there's something draining the battery, you need to disconnect it and get it on a decent charger, once serviceable you need to get a current meter on there to identify the drain, it could of course be the alternator given up the ghost Rolling Eyes
Post #343011 5th Jul 2014 3:31pm
K9F
Sounds to me the immobiliser is doing exactly what it's supposed to. Know anyone in your area with another Nanocom that may be able to confirm? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #343025 5th Jul 2014 4:28pm
Porny
Site Sponsor
Have you fitted new speakers as well as a new stereo?
Might sound a daft question but magnetic interference does some funny things to a 10as.... If the magnet of the new speaker is too close it can cause the vehicle to immobilise.... have had this issue on a customers Td5. IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #343034 5th Jul 2014 5:16pm
worzel
That's interesting Porny, yes the speakers are new but have run with them for a couple of months now on the old stereo and also they are in the same location as the original defender speakers what was the issue you had exactly?
Unfortunately I cant get another nancom to plug in as even mine wont read the ecu due to the power lost on that cable. Everything else in the cab is fine all 12 volts.
might have to give it over to the expensive people see what they make of it.
Post #343044 5th Jul 2014 6:27pm
K9F
Excuse my ignorance but I have absolutely no experience with a Nanocom but am an electrician. With the Puma diagnostics they are connected to the OBDII port. There is a single 12V feed to this port that comes off the battery and is protected by a fuse there are obviously earths, databus lines etc. It is from this supply my Puma diagnostic derives it's supply.
You mention "power lost to that cable."
Surely if you go back to basics and cure the loss of power to "that cable" there is a strong possibility the Nanocom would burst into life and hopefully give an indication where your issues lie?
Concentrate your efforts into that. What would happen if you 'jury rigged' (second time I've used that term today) an alternative 12V supply to "that cable" or the Nanocom 12V pin/socket and then connected the Nanocom? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #343048 5th Jul 2014 6:50pm
Clive
I've just been looking at the MY2002 schematics and there is a 5A fuse, Fuse 30, in the "Fuse Box Satellite (P109)" that feeds the 12V supply to both the Diagnostic socket and the Radio.
I'm not 100% sure where that particular fusebox is but I think it's the one next to the engine ECU under the drivers seat.
By the way Worzel, I've got a Nanocom Evo if you need to double check anything and I'm not so far away from you.
Post #343052 5th Jul 2014 7:09pm
K9F
Clive I think you're onto something here! Thumbs Up
You've probably dislodged a supply line or blown the fuse. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #343054 5th Jul 2014 7:16pm
