![]() | Home > Puma (Tdci) > What do you think they have broken... |
Windscreen! If you go through life with your head in the sand....all people will see is an ar5e!!
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
Handy i had a chip repaired on that...so i can even tell
Hope they havent Fu*ked the safari seals i spent hours doing Mike |
what are safari seals Mike 2.4 90 XS
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
i second the screen, they did with mine which not only did we loose a sticker but there was half a dozen smears of glue on it and i could still see the dinner plate sized sucker marks in two places, once again service i wouldn't pay for. all that said i wouldn't be surprised if it where your radiator grill, exhaust back box or damage to the top of the roof, any thing is possable
Right here is the list ive worked out so far
Top marks - windscreen ![]() It would appear indicator stalk The service manager is battling with land rover as he is clear it needs another clutch, this version (the 2nd generation) is not right They appear to have scratched a little bit of dash and there is some weird glue on the cubby box Another issue (thanks to Stratstones ever more amazing inability to touch a land rover without fing it up) radio code not correctly recorded after change - fortunately i was able to enter it Most of the behind dash brackets have been replaced, but i do need to check my Aux switch wiring as its all been moved ![]() On a plus I got a new windscreen - they have clearly adjusted all the doors Mike |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
sometimes makes you wonder about complaining about a minor fault and getting a hoard of further problems caused by mechanics who couldn't care less.
Been there many times! Mike |
Mike you got the truck back yet 2.4 90 XS
Yes thanks (although i dont know why) - they are expecting it to be in next week for the clutch (and realign the rear door i hope) after they get approval - service manager did say he wont accept them not giving approval as there is a clear fault - rattle asside its not selecting as it should and for the first time ive heard a service manager say:
"you shouldnt expect it like a silky smooth freelander or discovery gear box - but you should expect it to smoothly and cleanly engage" - finally what i had been saying to stratstone for 2 years ![]() ![]() off to find my spotlight wiring now - thank goodness for an camera inspection probe Mike |
what was wrong with the doors Mike 2.4 90 XS
Top not sealing properly Mike
have they adjusted the strikers then Mike 2.4 90 XS
Sorry i miss read - the front doors are all fine - they just seem improved in operation
Its the rear door they need to adjust Mike |
