Home > Puma (Tdci) > Why my turbo leaked
Page 1 of 3 123>
ZeDefender
Why my turbo leaked
Just out of interest, I set a ruler against the "leaky face" of the old turbo manifold. Two sides of the triangle were flat but the other...
A 1-2 mm warp explains why even the Nakatanenga gasket couldn't help :roll:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #342587 3rd Jul 2014 7:40pm
Dieselhead
Should be able to get that skimmed Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #342589 3rd Jul 2014 7:51pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
as said in previouse posts i had this problem on my 2.4 the only way i sorted it was to get it machined flat refit to car to run then had to do it all again after that it didnt do it any more same with td5 manifolds machine them flat once distorted and the problem disapears
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #342592 3rd Jul 2014 8:00pm
ZeDefender
Yup - skim it and sell it Thumbs Up Tell someone you love them today because life is short.
Post #342620 3rd Jul 2014 9:32pm
landy andy
You selling the pre warped one? Is it not best to refit warped once skimmed?
What money is a warped, now machined flat manifold worth Whistle Whistle
Andy
Post #342649 3rd Jul 2014 11:03pm
ZeDefender
Have just fitted a new BAS turbo. The improved internals are built into used units and skimmed, therefore (hopefully) won't warp any more. The picture is of the old one I took off. It will be machined flat and resold as it shouldn't warp any more than it has already, although naturally I will inform prospective buyers of its history Thumbs Up
Matt Tell someone you love them today because life is short.
Post #342654 3rd Jul 2014 11:15pm
landy andy
Ohhhh it's the turbo that warps not the manifold.
Post #342655 3rd Jul 2014 11:18pm
ZeDefender
Sorry - I'm not always so clear - should have said the turbo face onto the manifold Smile Tell someone you love them today because life is short.
Post #342660 3rd Jul 2014 11:26pm
Grouse
Chipped / remapped vehicles by any chance ? I have heard of this on quite a few Range Rovers where they have been remapped by dodgy engine tech's over fuelling and increasing turbo boost pressures in excess - causing overheating and warpage
Post #342673 4th Jul 2014 5:03am
ZeDefender
Remapped... but reputably by BAS - many others run the same system and don't have problems.
As big steve says above, if they do warp initially, once they are machined flat, they seem to be quite stable. Tell someone you love them today because life is short.
Post #342682 4th Jul 2014 7:21am
big steve
This is commonly know on standard cars also
Steve 2015 2.2 tdci hardtop xs
Post #342684 4th Jul 2014 7:30am
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Yes apparently it's not unknown for new and freshly machined steel/iron castings to distort after machining, known as 'green' castings. I came across it on a non-vehicle related product about 25 years ago which needed close tolerances - don't think they ever found a cure for that one. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #342857 4th Jul 2014 8:29pm
ZeDefender
So, the new turbo is being refitted with a copper gasket, as well as a temperature sensor to check I don't run it over 800 degrees C Thumbs Up Tell someone you love them today because life is short.
Post #343330 7th Jul 2014 7:43am
HMARR
What are the symptoms of a warped turbo? How would I know?
Post #343349 7th Jul 2014 8:52am
ZeDefender
It's just the manifold mating surface (triangular) that warps when it gets overheated. You would know when you get a screeching noise when you give it some gas (sounds like a slipping fan-belt or blowing through a blade of grass). If it gets bad enough, the gap becomes too wide to screech and you'll notice an exhaust smell in the engine compartment or through the air vents inside.
That being said, it's not likely to happen unless you're unlucky (like me) Rolling Eyes Tell someone you love them today because life is short.
Post #343377 7th Jul 2014 10:10am
Page 1 of 3 123>
