Home > My Defender > Silver 90 TD5 Build: Re-envisioning a great
Page 5 of 8 <12345678>
MrB
United Kingdom 2002 Defender 90 Td5 CSW Zermatt Silver
Now once back the refit began in earnest...
Nath
Post #342599 3rd Jul 2014 8:55pm
MrB
One area that consistently niggled at us visually were the side windows of the Defender.
Our self imposed 'design route' for the project was to create an 'evolution' of the Land Rover Defender. As initially shown, we had toyed with the idea of the floating roof design, using Landy Glass or similar, however as the project took shape and the vehicle gained its own presence we elected to stay true to the vehicles styling. However this still left us with the quandary of disliking the original 'ice cream truck' sliding side windows, as well as their constant vibration and security risk.
So after a little bit of discussion, sketch work and head scratching, we set about creating some templates for solid glass side windows and after a number of trial and error... we had a template we could give to a glazing company to create.
Although subtle we feel this was one of the greatest successes of the vehicle as it really transformed it. It's a simple modification, but choosing to treat the side glass like this suddenly created a more modern look to the classic truck's design... yet remaining sympathetic to it. A win win if ever there was one!
See what you think...
Post #342606 3rd Jul 2014 9:10pm
MrB
Then a few other choice parts were added as the front end slowly came back together... taking pride of place was a rather fetching Alive intercooler, plus a number of other select parts that I'll list out shortly...
Post #342608 3rd Jul 2014 9:16pm
MrB
The tinkering on the tuning and suspension side was well underway now...
Post #342611 3rd Jul 2014 9:22pm
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
Looking great! Really liking how clean and sleek it's looking!
Post #342612 3rd Jul 2014 9:23pm
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Looking superb Thumbs Up Darren
Post #342625 3rd Jul 2014 9:58pm
Caterham
would like to say what you're doing is great but,
that would be a huge injustice. absolutely brill Thumbs Up
Post #342627 3rd Jul 2014 10:00pm
Pickles
Mr8, top job you are doig here. Your soundproofing is the most thorough I've ever seen.
Well done, Pickles.
Post #342647 3rd Jul 2014 10:57pm
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
Fantastic looking vehicle there guys, inspires me to do my silver 110. How much do you think the deadening cost?
Post #342652 3rd Jul 2014 11:09pm
SailingTom
Great work Mr B
looks a really nice job, on my next one I'll have to follow your example with the sound proofing.
Those light guards look nice to take it you had them done custom?
Cheers Tom Defender puma dormobile camper
Post #342768 4th Jul 2014 12:59pm
MrB
Hi Guys!
Thanks loads for all the feedback. As requested by a few of you, I’ve outlined the costs of the sound deadening below, as it will give you a good idea of the level of investment it incurs. Plus I also elaborated a little on things further as I hope this will be a guide for others in the future.
4x Dynamat Xtreme Bulk Packs @ £119.90 each.
This is the silver tin foiled back material that aids heat management, removes panel resonance, removes road noise and effectively eliminates a great many rattles throughout. I still have some left, so my advice is buy two packs initially and see how you fair.
1x Dynamat Tape @ £9.99
This is a roll of silver adhesive foil that you double over the Dynamat Extreme panel seams with, creating a singular sealed cell, so that no sound can encroach.
6x Dynamat Dynaliner 1/8” Dampening Sheet @ £39.95
The Dynamat Dynaliner is the dark, thin foam base you will see in some of the pictures. It is designed to be added over the top of the Xtreme layer as it provides acoustic isolation and improved thermal insulation for the vehicle. Although only a foam based product its extremely durable, being crush and tear resistant and most importantly for a Defender owner it isn’t affected by oil or absorbs water! Smile Finally as Dynamat proudly state, it has the highest heat blocking properties available in a single layer synthetic foam-type material.
1mx5m roll of 600gsm 10mm thick Adhesive Backed Accoustic Felt @ £19.79
Now I bought this on special offer and it is effectively known as acoustic cotton. Most of you will of seen this as the grey intertwined material modern cars have under their carpets and panelling. This effectively works as a cavity filler and allows you to remove the drumming sound plastic and moulded interior panelling can create. As an example if you sit in the rear of a Defender and lightly tap on the roof panel you get a drumming sound. When you drive along the road this creates a large sound source that human ears cannot pin point directly, but it all adds to the drone often associated to utilitarian biased vehicles.
1.5M x 1M 3M Accoustic Insulation £11.95
This product is a new one from 3M and I have not mentioned it yet as we have not mentioned the audio side of the car… which I will add is very basic as I love great sound but despise loads and loads of speakers, amps and subs. This product can be best described as small foam pillow blanket that you place behind speaker areas. Various research showed that large percentages of a speakers audible sound could be lost from the rear of the actual speaker unit, if placed inside a badly sound deadened car. So the concept of this product is you roll it up and place it behind the speakers to give them maximum sound projection into the car vs. losing any of it into the dead space behind the speaker. Again, in isolation, I don’t know if this would be noticeable, but I do know I run a quality audio system that is not powered by any amps in the car, aside from the inbuilt head unit and it sounds superb – I’ll detail more on this though when we come to it.
1 x 50mm 3M HL Automotive Grade Double Sided Tape £17.89
Self explanatory but quality tapes are a must as you never want to be redoing this… and the best advice is if in doubt, put more tape on!
2 x Carpet Spray @ £10.00 approx
Again this just helps tack larger vertical areas life roof, side pillars and so forth.
Aside from the specific sound deadening materials outlined above, we also fitted the following products which also aid at removing the mechanical drone of a Defender’s drive train. However improvements from the above were very noticeable without these items being fitted as well, just incase you’re opting for carpers and such like. Like I have said previously, it’s a case of each addition removes a sound level, so when combined you see greater benefits.
1 x Wright Offroad Front Mat system @ £350.00
1x Land Rover load matt @ £128.00 approx
So how good is it… well naturally its very subjective. However I can tell you I have two niggly squeaks in the Defender currently emitting from the drivers seat (courtesy of the poor workmanship we incurred in the valley!) and the drivers side interior trim window surround that I need to address for my own sanity. Which just shows you how quiet it is. When I first bought it, everything rattled, boomed, droned and so forth… you had no reference or could even pin point anything and bear in mind our truck was a highly specced CSW.
One final example of the new refinement was the comparison of the first drive home after purchasing the car to now. Just as I shook hands, took keys and walked across James French’s car park, Mum called shotgun and jumped (well awkwardly clambered up) into the passenger seat. She was all enthused and excited until we covered about a mile. I looked over, smiled and she shouted “Is it supposed to be this noisy!??!” Now bear in mind we were only doing 55mph on an A road. I explained this is what they were like and the rest of the drive back was frequented with shocked looks from her at my new acquisition.
Now jump forward in time to literally the other night and I asked my brother to try the truck out as I noted how well it had been running using a new fuel. After it had warmed up fully, we went to a private test track (ahem) that we like to use as it has extensive sight lines, and he was nipping along in excess of 85mph with the pair of us just talking at normal volume. Now externally the truck is louder than when purchased courtesy of a much freer breathing system that exits in a somewhat loud single box stainless exhaust. And anyone knows that the TD5 warble is quite something sound wise at a fair speed… however internally it is very, very refined indeed. Best of all worlds in my opinion.
My best answer to the age old question of 'Is it worth it?' is, there are many things in hindsight I would never of done to the vehicle. At times I think we all let others experiences influence us and we put aside that their expectations may be polar opposites to our own. However if and when another Defender enters the household, this process will always be top of the list. In my mind it makes the Defender (at least in County spec) what it should of been from the factory.
I hope this is of use to you all!
Nath Very Happy
Post #342787 4th Jul 2014 2:20pm
MrB
SailingTom wrote:
Great work Mr B
Cheers Tom
Hi Tom,
Thanks so much, if you ever need any advice on your own project in the future, feel free to ask.
In terms of the light guards, yep these were prototypes of ours that we had been developing. They use some very trick engineering in them for strength as well as creating some subtle aesthetics to compliment the Defenders natural panel lines.
We wanted to also design a set that were significantly lower profile, than say conventional LR Defender light guards and when fitted they literally blend in (especially when colour coded).
We also took influence for the design of these from the wider Land Rover range i.e. freelancer, Range, Disco etc. that all employ a hooped design around the main light sources. I'll try and show some more close ups as we go on and fit these as the pic doesn't do them justice for the level of detail in them.
Thanks again for the lovely feedback!
Nath
Post #342789 4th Jul 2014 2:30pm
MrB
Just seen I'd missed a few other posts so big thanks to Freypal, DarrenJ, Caterham, Pickles, Charliebaja
Nath
Post #342790 4th Jul 2014 2:34pm
gilarion
Great looking Land Rover and Worthy of all the hard work put in.
Out of interest where did you source those front light guards never seen them before.
Post #342826 4th Jul 2014 5:31pm
charliebaja
MrB wrote:
Hi Guys!
Nath Very Happy
Who did you buy all of the Dynamat from?
Post #343069 5th Jul 2014 8:16pm
