![]() | Home > Maintenance & Modifications > Am I doing this right Info wanted on headlight loom upgrade |
Yeah,that sounds about right,as easy as that,fwiw, I ran a live direct from the alternator. Pov.spec,ftw. 2006, 110,TD5.
^ what he said. I also fitted the live wire direct to the alternator. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 728 ![]() ![]() ![]() |
I've got one on the shelf ready to be fitted (along with a lot more stuff when time permits!) and the instructions say to connect direct to the alternator. Other than that, do exactly what you plan.
For those that have one already fitted, is the benefit perceivable? If its really good i'll bump it up my to do list. Thanks |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
I made my own up, using decent gauge wire, so can't comment on these ebay sets, but otherwise, yes, there was a very noticeable difference on mine. Largely because lights were receiving the correct voltage, not 10-11 volts as it was previously.
And the switch shouldn't now melt |
Fitted Crystals, loom and Nightbreakers when I did mine,so can't comment on wiring loom mod.But as whole, yes a lot better,although I only used them for the first time last night,lol,roll on winter and dark nights
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 492 ![]() ![]() ![]() |
Loads better, I had ordered the Chinese ones but they never turned up. I made my own up and ran straight from the alternator, so now rather than 10 and a bit volts I get over 13 at the connector, almost a 30% rise in voltage and loads more light. They are now white rather than dull yellow
![]() ![]() 1994 Def 90 300tdi |
