Home > Maintenance & Modifications > Should I? - New shocks.
I am going to have to replace my shock bushes soon, but I was going to keep the same shocks.
I want to keep OE shocks as other decent types are too spendy right now for me.
Question is new take off (genuine) shocks seems to go fairly cheap so would there be much point in fitting new / nearly new?
My current shocks are on a 57 90, only done 40k but are 6 years old now.
Would there be any worthwhile point in changing?
Or just stick to doing the bushes?
Post #337248 10th Jun 2014 4:26pm
GUM97
If it was me, unless there was anything wrong with the shocks (inspect them close up), then I'd just stick to the bushes. If it's getting a bit 'wallowey' then they may want doing, but otherwise save your money Thumbs Up An engine to TDi for!
Post #337252 10th Jun 2014 4:56pm
Not willowy (I know what you mean) but is rattly over correlations in the road. (Which is the bushes)
I'll just do the bushes then. Mr. Green
Post #337256 10th Jun 2014 5:06pm
K9F
I considered the same when I did my bushes but I too discoubnted the expenditure as there was absolutely nothing wrong with them. With the Pro Bushes you know it won't take long to swap the shocks out if and when they need doing. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #337263 10th Jun 2014 6:08pm
That is very true, I know the rears should be no trouble and for the fronts I intend to follow the guide on here.
I'm gonna get two genuine turret rings to be on the safe side though too, so if the worst come to the worst and one of the bolts shear I have a replacement.
I'll wd40 soak the appropriate areas though a few days in advance.
Shouldn't be in bad nick as it's Dinitrolled anyway, just might have to clean the threads.
Post #337264 10th Jun 2014 6:23pm
Killer90
Site Sponsor
For what its worth i would personally replace shocks aswell then you know there sorted Thumbs Up set of new take offs will be fine and very cheap. I got a set here aswell Whistle Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #337274 10th Jun 2014 7:02pm
Got my voicemail then. Rolling with laughter
Post #337275 10th Jun 2014 7:04pm
GUM97
Typical Essex boi Rolling with laughter "You didn't know you needed some until I've got some for sale!"
Rolling with laughter Rolling with laughter An engine to TDi for!
Post #337281 10th Jun 2014 7:19pm
I offer £10 + P&P Twisted Evil
Post #337283 10th Jun 2014 7:29pm
jimbob7
I also bought new take offs,one of the reasons (apart from being cheap),the top nut on the front shocks had rusted solid (another mudtrap Banging Head ) and will need grinding off,so you might wanna check yours anorl. Pov.spec,ftw. 2006, 110,TD5.
Post #337314 10th Jun 2014 8:48pm
That's worth bearing in mind, I shall have have to check when I get the chance.
Post #337322 10th Jun 2014 9:02pm
Killer would sell his foot if he had a buyer. Rolling with laughter
Joking aside looks like I have a set of new shocks curtesy of Killer. Mr. Green
Post #337519 11th Jun 2014 5:33pm
Just out of pure interest, are 110 shocks different to 90 shocks?
By this I mean from the factory.
Post #341939 30th Jun 2014 10:08pm
You don't realise how poor your dampers are until they're off.
I've JUST removed my fronts, they were totally goosed. Compress them and that's where they stay.
I always start a project with quality dampers and bushes. Coils are usually shot too and they always look wrecked with the plastic coating flaking off.
Post #341942 30th Jun 2014 10:13pm
jimbob7
/\/\/\Normal that dude Thumbs Up .Its the spring that makes it rise,you should however feel good resistance pushing or pulling the damper. Pov.spec,ftw. 2006, 110,TD5.
Post #341945 30th Jun 2014 10:29pm
