![]() | Home > Td5 > Where does this go |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
it is a cover for the front door restraining bar/check strap thingy 2002 110 td5
isn't it the cover over the door stop bar , coves the bit where it slides in and out on bottom corner of dash
near side 2002 110 td5
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 242 ![]() ![]() |
You gents are bloody brilliant
![]() Click image to enlarge Defender 90 XS TD5 (03 Reg) |
Not so much brilliant, just good at identifying all the bits that fall off!
First, "It is a bit off mine" and second, "Now where in the hell did that come from?" |
It's when you can recognise a random bolt that you find you realise you have spent to long under the car Defender 90 XS TD5 (03 Reg)
This/\/\/\ Pov.spec,ftw. 2006, 110,TD5.
