Home > Td5 > 2001 110 Station Wagon
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Hi folks,
I'm looking at a 2001 TD5 110 Station Wagon, looks in good nick generally with only the doors that look to be in bad condition.
I have however noted a couple of things I'm not 100% sure about.
Weeping oil on the sump (looks like sump gasket);
Weeping oil on the transfer box (not sure if it's gearbox or transfer box oil);
The transfer box was replaced about 18 months ago with a disco box.
Anything I should be concerned about?
The sump gasket looks like an easy enough fix, but what's the reality???
Thanks in advance for any advice offered.
Post #341509 28th Jun 2014 10:29pm
familymad
You are going to find they all weep! See it more as 'marking its territory' ! 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #341541 29th Jun 2014 8:18am
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
It's just gaskets, they are everywhere and decompose after a while causing leaks.
Just had my engine sump gasket replaced which was causing a leak since bought the car over a year ago, garage found the turbo gasket was leaking too!
Post #341554 29th Jun 2014 10:27am
ROBBONTHEROCK
Thanks,
I guess that's the question, are the seals on the crankshaft and gearbox normally quite good, I.e. Not a common weakness?
I'm ok with wee page provided it's not serious and it's fixable by me.
Gearbox out job is not something I can or would wish todo on the driveway.
Post #341561 29th Jun 2014 11:16am
ROBBONTHEROCK
Hello, just a follow up note.
I bought the truck today, get it next Saturday.
Will post pictures when I pick it up - very excited Thumbs Up
Post #341685 29th Jun 2014 10:26pm
