Home > Maintenance & Modifications > Long range tanks
Page 2 of 3 <123>
BigRuss
Well 290 is a lot of fuel and say an average of £350 per fill would not only be costly but it would take about a hour to do! but do the tanks have pumps and guages or are they gravity fed?
On the other hand with an average of 12000 miles a year you would only need to fill up 6.5 times. Just the though of spending more time away from the pumps is great.
If you protect the tanks properly underneath it means there will be no need for any jerry cans on the roof thus brining the overall vehicle centre of gravity down nice and low, counter acting any rollcage/roof rack/roof tent.
Post #34109 10th Jun 2010 12:29pm
leeds
Wing tanks are gravity fed into main tanks The wing tanks on our vehicles are doubled bottomed for protection. Cill tanks/pods need pumping.
12,000 miles a year Rolling with laughter Laughing Rolling with laughter Laughing One recovery trip was 3,500 miles Razz Our overland trips are normally 8- 25,000 miles.
Most people don't need that sort of fuel capacity . However we run on about 160 litres capacity and top up when the opportunity arrives. 200 miles between fuel stations with one fuel station out of fuel then you need large tanks! Especially when your mpg drops from say 30 to <24 mpg Lowest mpg I have recorded is 18 mpg on a 300TDi.
Have come across fuel stations with no fuel due to road conditions not allowing tankers through Another occasion fuel station with plenty of petrol in underground tank but electric pump not working!
Brendan
Post #34122 10th Jun 2010 2:04pm
angus1886
1998 Defender 110 300 Tdi HT Alpine White
I have one feeder tank in rear wing (waxoiled mild steel), plus a side box that takes 2 jerry cans (sometimes I take water, sometimes fuel, depending on destination and number of people): this gives a v flexible set-up.
only problem with the wing tank is that you don't know how much fuel is left until you start drawing on the standard tank, but it doesn't take military planning to know how far you have travelled since filling up!
Post #34585 17th Jun 2010 12:37pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Presumably if you got into the habit of filling it each day from the jerry cans then you'd be bale to monitor consumption easily.
I think I'll stick to cans for the time being. I'm sure an extended tank is the right solution but I don't have any plans that would require anything more than cans (actually if I'm honest, I don't have any firm plans at the moment that aren't within reach of a petrol station - ho hum Embarassed ). One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #34589 17th Jun 2010 12:57pm
BigMike
Old thread I know but I was looking for something else and came across it. I have the new safari equip tank which is gravity based. Great design, absolutely no interference with wheel/suspension travel. Cheap (ish) too, at least far more so than the others. There's a small balance valve at the bottom so ensure full drainage too, its a simple yet clever thing. If any of you are interested have a chat with Adrian or Tom at Safari Equip. They fitted mine too, 60 quid, which was a bargain, as it isnt straightforward.
Post #43853 29th Oct 2010 12:01am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Hi Mike,
do you have a link or any photos? how big is the tank?
Cheers! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #43857 29th Oct 2010 6:29am
BigRuss
I had a chat with them when I was at billing, great guys I think they quoted me £800 ish for a main and the wheel arch tank + fitting with both twin skinned S/S bottoms.
I also had a good look round brendan's 110 which had them fitted. He did say that you need to state your model year when ordering because the new pumas are different from the first ones. Russell
2011MY 110 XS USW Black
Post #43865 29th Oct 2010 9:07am
marcoegyptos
France
I got and install this one LRA 140 LITERS
http://albums.photoonweb.com/marcoegyptos/...serv01.jpg
Post #43867 29th Oct 2010 9:17am
BigMike
wyvern, its this one -
It's high density plastic, very nicely made. I just had a look at the safari equip site and its not on there yet, its a new product. From memory its either 25 or 28 litres, cant quite remember which. I get around 500 miles from empty to full. Give them a ring and they ll tell you more about it. it was definitely less than £300.
if you look at the pic, you can see the "arm" which goes to the right, on the left its harder to see but it "wraps" around to the point it reaches the normal fuel filler, you can just about see the join from the curved section to the flat section. fixes with two very sturdy brackets. Its been to morocco and had miles and miles of heavy corrugation to deal with, and some fairly hairy offroad stuff in terms of shaking and vibration. No problems at all.
Post #43868 29th Oct 2010 9:33am
Luismi
Spain 2004 Defender 110 Td5 SW Alpine White
Hi Brendan I just finish to install the 120 litres replacement fuel tank in stainless, exactly as yours. my doubts it is about the fuel pump
You need to modify somehow the fuel pump? as in the side has a lip that makes the pump not sit properly.
I believe yours its a puma mine is a 2004 TD5 don't know if the fuel pump its the same.
Thank you
Post #266702 14th Sep 2013 7:37pm
walfy
James
Did you sort out a tank or is this an ongoing project still? 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #266812 15th Sep 2013 9:10am
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
I prefer these Laughing
Post #266821 15th Sep 2013 9:54am
walfy
A nice T55. Where is that? 110 D250 SE HT
110 USW SOLD
Post #266842 15th Sep 2013 10:35am
jst
yes i did, Brendan supplied one, 45L side tank in the end. easy to fit and fills off the main filler and that fills the main tank.
105/110L tank now, i loose a bit as i didnt fit a balance pipe, too vulnerable in my opinion Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #266881 15th Sep 2013 1:20pm
walfy
Many thanks. Did you get any pics of the instal. Had a look in your gallery and nothing there. Can mail them to me if to many to post on here. 110 D250 SE HT
110 USW SOLD
Post #266883 15th Sep 2013 1:22pm
Page 2 of 3 <123>
