Home > Puma (Tdci) > TDCI ticking under load
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Hi all,
I'm a bit lost now I've got rid of the 300tdi, I'm on LRO's forum but it seems there's not a huge experience of Pumas on there. Time for a change then I suppose !
I bought this defender with 100k on the clock, mainly motorway miles and it's been fantastic until this.... Oh and the seized wiper spindles..... What a pig of a job !
I'm get a loud and fast ticking from somewhere in the engine bay when I push the engine. Generally it's when I'm pushing her over 60-65 going up hill or when accelerating moderately at 70.
I had the cattle trailer on last week and with that loaded up it did it going up every hill even at 10mph !
So it seems to be load related. My local specialist thought it was the fuel rail sensors ?? Which were changed at great expense and hasn't made the slightest difference .
I'm thinking injectors or turbo related.
Anyone have any thoughts or similar experiences ?
The diagnostic tool comes up with absolutely nothing. I'm sure the sounds getting louder and I don't want the engine to eat the turbo.
There are no leaks anywhere.
Cheers guys
Post #340989 26th Jun 2014 3:37pm
First thing I'd check would be that I didn't have a loose injector.
Post #340991 26th Jun 2014 3:49pm
Bluericky
Thanks, I've just checked and all seems fine. No.1 looks a little wet around the head but nothing serious
Post #341038 26th Jun 2014 7:47pm
the gamekeeper
England 2007 Defender 110 Puma 2.4 DCPU Tonga Green
I agree with Blackwolf, I had that problem and it was injector no.1 that was loose.
Post #341069 26th Jun 2014 9:52pm
do you have all other auxiliary items switched off ... Aircon, fan etc?
try switching all items off, if you still get the noise then it's either the engine or gearbox
are you suffering any vibrations at all ?
UJ's, Props ??
Post #341072 26th Jun 2014 10:13pm
Bluericky
I thought I ought to mention the fix.
It turned out that two injectors were shot, to be expected on a 120k defender I suppose. I replace all four and it's done 2k floorlessly since !
I must point out though that both a Land Rover expert and a Bosch diesel specialist didn't pick this up so don't take their word for it !
Post #624951 17th May 2017 8:34pm
Out of interest did you ever try a fuel treatment?
I'd be curious to know if you use any, or did to try and cure it?
I'm guessing maybe not at all? ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #624958 17th May 2017 8:55pm
Bluericky
Yes I tried some Wynns and also a tank of high octane diesel but that didn't work.
I had to bite the bullet and purchase new injectors . Glad I did though as the change was instant, far more power and the engine was quieter than it's been in months .
Currently about to sell the defender but trying to get to the bottom of an intermittent immobiliser issue ! Need to do it ASAP as I've already bought another !
Post #624960 17th May 2017 8:58pm
YOLO110
Australia
Buying another one is certainly one way to effect a permanent repair!!! Rolling with laughter YOLO... You Only Live Once...
Post #624968 17th May 2017 9:18pm
Thank-you. Thumbs Up ____\We|Will|Win/___
Post #624970 17th May 2017 9:21pm
Bluericky
Here she is , absolutely fantastic 110 xs, only selling as purchased a Keswick green double cab (what i always wanted !) .
I'll pop the boost alloys back on and take the winch off as it's only been used three times . Don't want someone negotiating on that !
Post #624977 17th May 2017 9:45pm
