Home > Technical > headlights coming on
dancerdave
United Kingdom 2000 Defender 90 Td5 Exclusive HT Santorini Black
On my 2000 TD5 when I turn on the sidelights with the engine off all is okay but with the engine running the headlamps light up Confused
Any one any ideas Question
Post #340860 25th Jun 2014 11:29pm
JWL
Most probable cause would be the light switch breaking up internally. With the ignition switch off you wouldn't get headlights to come on anyway even if it is working properly, i.e. if you stop the engine with all the lights on when you turn the key off you are left only with the sidelights. If you turn the key to position II then all the lights are on even if the light switch is in the sidelights only position? Pretty much points to the weak link.......the light switch, easily replaced.
Post #340862 25th Jun 2014 11:54pm
PaulMc
Re: headlights coming on
It's a system called 'Dim-Dip' - it doesn't allow you to drive with just the sidelights on.
With sidelights selected on the main lighting switch, once the engine starts, it powers the dipped beams on a reduced power.
It's a system that Land Rover put in place to meet an EU lighting regulation that never was.
It's not a legal requirement, or an MoT testable item - there's lots of info on here and other forums, on how to disable or by-pass it.
On a TD5 of your age, Dim-Dip will be implemented using a Pink relay behind the instrument cluster, and a large resistor mounted to the RH inner wing.
. Paul.
Post #340864 26th Jun 2014 12:08am
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I believe there is a resistor in the wiring that gives a very limited amount of current to the headlights with position 1. That resistor might have failed and is just giving full current to the headlights.. it is disabled via relay when you take the key out which is why only the sidelights stay on.
It is located under the inner wing so bonnet up!
You can disconnect it to disable headlights on position 1 but check that position 2 still works Thumbs Up
Absolutely no point in keeping it..
edit: what PaulMc said!
Post #340865 26th Jun 2014 12:18am
dancerdave
Many thanks guys Bow down
That's why I love this forum
Post #340903 26th Jun 2014 9:15am
K9F
You learn something new every day. Thumbs Up
I never knew about that feature. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #340911 26th Jun 2014 9:52am
JWL
Ah, you didn't say that the headlights were on but at a reduced brightness with the engine on, if the headlights are at full brightness and you don't have dim dip fitted, not all do, then my previous statement is a likely cause.
Post #340914 26th Jun 2014 9:54am
mrd1990
I think the ultra dim dip with position 1 and the resistor is barley noticeable until the resistor fails and lets out full current.
With my old L322, when the blower motor resistor failed, the fan came on at full power which is why it appears the headlights are properly coming on Surprised
Post #340969 26th Jun 2014 1:31pm
jimbob7
I recently disconnected my dim dip,lift bonnet, tucked under O/S, wing near brake M/C, I didn't know I had it till it started playing up. Eventually only had dip beam, couldn't only have the side lights on.Some people rewire the relay,dont know why if you can just unplug the resistor?? Pov.spec,ftw. 2006, 110,TD5.
Post #340997 26th Jun 2014 4:09pm
