![]() | Home > Td5 > 400 miles from a tank! |
I don't always moan.. hopefully those comments made some of smile
.....certainly made me smile ![]() Thanks Keith ![]() |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2274 ![]() ![]() |
You don't belong in the 400 mile club mate , your in a whole different ( special ) league .
![]() 600+ ![]() Nobody believed me either when I used to get 28mpg in my 2.25 S111 petrol . ![]() |
Well rant you just a ![]() ![]() 2011MY 110 XS USW Black |
I'll tell you what I wana know
![]() If the 5 cylinder with 5 gears Gota range of around 400 Then why should the 2.2 4 cylinder with 6 gears get the same or LESS ? ( more economical ) it ain't ![]() |
I wouldn't have thought it's anything to do with it being a smaller unit trying had to achieve the same as the 2.4 as I'd have thought that would be marginal....i guess it's down to the dpf strangling the engine ?
Ogre1231 Member Since: 27 Jun 2014 Location: Suffolk Posts: 3 ![]() |
Nice!
simon67 Member Since: 18 Jun 2015 Location: west sussex Posts: 569 ![]() ![]() ![]() |
04 HT 90 with 86k on the clock
1.2 gearing with Alive stage 1, EGR blanked and cat removed Don’t drive like a loon but getting 24 MPG around town Normal or something wrong? |
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 ![]() ![]() |
Probably ok - I think (and I’ll be corrected if I’m wrong!) that the 1.2 gearing makes high speed more efficient but you might have to use more grunt in the low gears. If you’re chipped, and so squeezing more horses out of each sip of fuel, you might find that around town you’re developing too much power and not enough torque for the sub-40mph speeds?
