Home > Technical > TD5/TDCi Radiator
TD5/TDCi Radiator
Does anyone know if there's any difference between PCC001020 and PDK000100 ?
The former is the number in Microcat for a (2007) Puma, but is described as a TD5 radiator and is also listed as fitting all TD5 Defenders, however the latter part number is also listed as fitting all TD5s. They may be the same, and it is the old LR trick of changing part numbers.
The confusion thing is that several online suppliers list both and the PDK part is around £50 less than the PCC part. That I can't explain if they are indeed the same!
Also, does anyone know who makes the original radiators for LR, or a source of a good quality good value non-genuine one, NOT BRITPART!
Does anyone happen to have a (prefereably genuine) TDCi radiator they don't need and would sell me? I seem to have a very small hole in mine.
Thanks.
Post #340709 25th Jun 2014 1:09pm
grafty99
I seem to recall seeing a Calsonic sticker on the top of mine but I couldn't say for sure, I'll have a look when I've finished work Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #340722 25th Jun 2014 2:36pm
Thumbs Up
Post #340730 25th Jun 2014 3:36pm
There were two types of Td5 radiator (for EU2 or EU3), one had an extra water pipe at the bottom, a small one (1/2" or so).
Some rads came with the pipe moulded in place, but the hole blanked off, you just drilled it out if you needed the pipe to be there.
Think it was for the fuel cooler. or EGR
Post #340737 25th Jun 2014 4:13pm
grafty99
Looked this evening and it is indeed made by calsonic Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #341320 27th Jun 2014 11:14pm
